Jet Black turbo
#31
Macan without AS is the normal ride height.
Macan with AS normal ride height is -15mm lower.
Sports plus IS REQUIRED to lower car further 10mm and it ONLY happens with the car in sports plus mode.
Off Road setting raises car +40 mm from AS normal ride height.
Cargo area button lowers car -50mm from AS normal ride height for loading and unloading ONLY.
#32
@ISUK... Looks like your Turbo has the rear seats vents, which per Porsche also come with an A/C vent in the glovebox for cooling.
Would you be kind enough to look inside your glove compartment and see if those particular cooling vents have a vent open/close slider/switch ?
