Thought I'd Share My Macan S build
A true driver's build:
-white ext/black int
-21" wheels
-sport seats with heat
-pasm
-chrono
-ptv
-matte black window trim
-fire extinguisher (of course)
Getting rid of my '13 991s with pse for a car that is more practical :thumb up:
Anything I missed in interest of a driver's macan s?
-21" wheels
-pasm
-chrono
-ptv
-21" wheels
-pasm
-chrono
-ptv
-21" wheels
-pasm
-chrono
-ptv
Excellent points by all-
Gloss black trim - thought this was delaying orders?
Ventilated seats - had those on a previous 997.2 - good idea I will add
AS - Not a fan of the AS in the cayenne so I figured I would just changeout the springs at some point to lower it a bit as I don't plan on doing any offroading
Air suspension would be a better option for spirited driving than off-roading:
Much lower center of gravity and fine tuned suspension by Porsche would be my pick over an aftermarket solution for this car.
"It’s something you wouldn’t normally associate with this segment: air suspension including leveling system, ride-height adjustment and PASM. With this set-up, the Macan is 15 mm lower than with the steel spring suspension. The air suspension delivers even greater dynamic performance and comfort – and helps to keep the vehicle level constant."
Why did you say the 991S not a practical car? You are in FL so there is no snow.
What qualities in a Macan drove you to make this decision? I am debating between Macan S vs. 991 TT.
Yes, apples and oranges but thats how the game of elimination down to....
20's and AS I'd add to make it a better drivers car (20's because they're probably lighter, will handle the same and will absorb bumps better). And staying away from as many creature comforts that you don't need, that can add weight. IMO the base seats are a sportier choice than the 14 ways as not only are they most probably lighter, but the alcantara gives it that sporty feel that Porsche usually gives it's rawer offerings, i.e the GTS cars, GT3, etc. 18's ways are obviously the sportiest choice, though I imagine they way a bit more.
