Macan 2014-Current
Sponsored by: HBI Auto
Macan GTS Competition
Old Apr 6, 2026 | 07:48 PM
stiles_s's Avatar
stiles_s
From: Bellevue, WA; '26 MacanGTS, '18 Macan S, '10 997S, SPASM, 6spd
Originally Posted by malibu515
My test drive in the Macan S last year did show that the S had a noticeably more compliant ride than the GTS. It also had steel brakes as compared to the coated brakes in the GTS. The steel brakes are easy to modulate whereas the coated brakes remain a nightmare to use. I went for the GTS because it offered more options and seemed to have more power. Quite frankly, considering how much I dislike the grabby brakes and the overly stiff ride (my opinion and also passengers), I wish I had purchased the 2025 Macan S, instead.
Really surprising comment re: the brakes. I haven't found them to feel any different than the brakes on our S.
Old Apr 6, 2026 | 08:08 PM
Carlo_Carrera's Avatar
Carlo_Carrera
I would wager if you swapped out your current GTS sway bars for the S versions you would be more happy with the ride quality. It would not be too expensive nor hard to do.
Old Apr 7, 2026 | 08:24 PM
DHL's Avatar
DHL
Also surprised about your comments re the brakes. My 22 GTS has them and besides being a little grabby cold at low speeds I find them wonderful when warm. Maybe you have contaminated rotors for some reason. I would go out and do some hard braking tests from 50 or 60 mph (similar to bedding in new pads) and see if they don't improve. Like most things Porsche they are made to be used and not babied.
