Macan 2014-Current
Sponsored by: HBI Auto
Autel scanner
Old Dec 8, 2024 | 06:48 PM
DHL's Avatar
DHL
Default Autel scanner
I have a MX808 Autel scanner I bought for my 2017 991.2 Carrera and it worked fine when updated in 2020. Can I use this same scanner on the 22 GTS if I update the software to the most recent REV, or is this scanner too old to work on the 22 ? So far, could not get a definitive answer from the tech at AES Wave, the Autel dealer I bought the scanner from. They are recommending another brand and a newer release.
Old Dec 9, 2024 | 04:06 PM
chong0's Avatar
chong0
I am using that scanner (I think it's the MX808BT) with software for 2022 and works fine on my Macan/Cayenne/911.
so unless there is a big difference between the MX808 and the MX808BT as long as the software is updated I would assume it would work
Old Dec 9, 2024 | 05:45 PM
DHL's Avatar
DHL
I'll check out the BT specs. When was this model produced?
Old Dec 9, 2024 | 06:11 PM
DHL's Avatar
DHL
I checked out you BT and it was just recently released in 23. Way more recent than my MX808 so it stands to reason that it would work with your cars.
