Macan 2014-Current
Sponsored by: HBI Auto
CETE Suspension Module - Alignment needed?
Old Aug 7, 2024 | 11:44 AM
Slngshot's Avatar
Slngshot
Default CETE Suspension Module - Alignment needed?
Hello,
I've gone ahead and ordered the CETE suspension module for my '24 GTS
my spec has +10mm
the idea is to take it -20mm from it's raised stock height.
as the suspension is rated to handle the drop from stock to lowered height with pasm/air suspension - should I just book an alignment when it's dropped that extra 10mm or there's no need, the suspension adjusts things and I won't shred a very expensive set of tires?
CETE owners seem to be happy, but I could not find if anyone needed alignment in my searches.
Cheers
Old Aug 7, 2024 | 11:58 AM
por356's Avatar
por356
Same question regarding drop links.
Old Aug 7, 2024 | 09:00 PM
Slngshot's Avatar
Slngshot
I’ve concluded to have the alignment done once I’ve found the setting I want.
I’d suggest same for drop links.
Old Aug 8, 2024 | 02:15 PM
Vise's Avatar
Vise
I just installed the CETE module on my 2023 Macan GTS a few weeks back and so far have no plans to get an alignment done. Based on my current settings, it is a relatively mild drop (-10mm roughly over the current 'low' mode) and I don't drive much so I'm fairly confident it will be fine. I've never seen any mention of an alignment related to the CETE module in all of my research but I could be wrong of course.
