What is special about Porsche Headlights that it does like PPF’d
Hi,
We all know the recommendation or warning from Porsche to not have any protection film or PPF on headlights and the possibility of voiding the warranty.
Isn’t applicable even for other make and models such as Volkswagen vehicles or BMWs. I see this concern only from Porsche while i am expecting this atleast from VW Family of vehicles
Apparently, there is a coating on the lens surface. If, for some reason the PPF must be removed this coating may be pulled off with it. Porsche will not warranty replacement of this coating which actually requires a new headlight assembly (read=$$$). In any case, this does not affect the warranty on any other part of the car.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
isugoo (04-18-2024)
isugoo (04-18-2024)
Apparently, there is a coating on the lens surface. If, for some reason the PPF must be removed this coating may be pulled off with it. Porsche will not warranty replacement of this coating which actually requires a new headlight assembly (read=$$$). In any case, this does not affect the warranty on any other part of the car. ![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
I still PPF them. My thought is they get wrecked if not PPF'd anyway so you end with the same result, and with PPF at least they don't get all pitted. The UV coating that MAY get pulled off if you remove PPF offers zero protection from pitting.
Also my detailer has told me he has had the coating come off with removal on a Porsche headlight, he was able to easily polish the headlight back to gloss and then put new PPF over it.
rasetsu (05-03-2024)
Hi,
Had to do my Suzuki headlights a bit earlier but that does a lot if off road stuff.
Is it possible that when Porsche was still running xenon bulbs the surface got too hot? Now witht he advent of LEDs running cooler it's not an issue in recent years. Just asking....
Full front PPF including headlights and windshield for 5+ years with zero issues. I have replaced the windshield protection once due to wear and tear which I anticipated. I also have PPF on my Cayman headlights with no problems.
Good point and good question. I don't believe Porsche headlight lenses are somehow more special than those from every other manufacturer. I suspect it's just legal response to some rash of customer complaints who had PPF removal that took some of the coating with it and then tried to pass the issue onto Porsche.
The logic of all the responses above is why I PPF'd mine. I have PPF on the headlights of both of my Porsches for a total of 13 years and counting with no issues due to the PPF being on there. I'm sure they are out there but I have personally not seen or heard of anyone having delamination or crazing issues with PPF'd headlights. The only ones who have those issues experienced it without PPF on headlights.
