wrapping side blades
They are not snap off, they are secured by double sided tape and some clips that may break off into the door when removing. The removal is tedious but doable.
There are holes in the door that these cover so it's important to remount with the tape properly to ensure waterproofing and no intrusion into the door skin. As I mentioned earlier, you don't want to remove if you don't have to.
