Just bought a 2017 Macan and can you replace the headlight lens’s ?
I bought a Macan GTS and the headlight lens’s are terrible. They work excellent and shine bright at night, but cosmetically look bad.
I did the 3M headlight restoration and also paint correction with rubbing compound, then polishing compound and it helped only a little.
I think all the scratches are on the inside somehow.
Instead of buying new headlights, is there a way to just replace the lens’s?
Thank you
Thank you
No. Sealed unit. You can try Ebay for a used one in better condition or use one of the headlight restoration products, some of which work very well.
https://www.caranddriver.com/car-acc...8&gad_source=1
