Removing gear shift knob
Hey members!
New to join the forum. I have a 2016 Macan S for which im trying to remove the PDK shift ****. The replacement I have purchased turns 45deg clockwise but the one in my car won't turn in any direction. I've even used pliers with a soft cloth to grip and turn and I'm hearing cracks and creaks but it won't budge. I've changed it to the different positions too, but no luck.
Anyone have any advice or a video of how to remove the shift **** from the car plz?
Hey members!
Unfortunately not the same. I've seen the 911 video too, but the Macan gear **** doesn't have any collar. It's attached directly to the leather surround. Even the replacement has nothing under the leather. It just turns with a little bit of effort
chassis (01-11-2024)
Are you trying to rotate the whole **** assembly 45 degrees? On my 991 there's a small collar towards the bottom of the **** that you rotate (might be what they are trying to depict in the photo above?). If there's a small separate collar piece, try rotating that instead of the whole **** assembly.
My 2020 base has leather surround.
