How complex to swap the rear light panel of gen 3 Macan S to the clear version
Would love to swap the rear light panel to the clear version. Has anyone here done this? How complex of a project would that be? Is there a risk to damaging anything? I see Suncoast has the kit on sale for under 1000 bucks and I am really tempted to just go for it. Any advice would be highly appreciated.
The basic steps are simple. Rear hatch cover needs to come off. There are torx bolts, 6, that hold the panel on. 2 are under the flip open panel in the center, the others are behind the grab handles at the bottom. Those are covered with a thin vinyl/plastic cover that comes off with a hooked pick or similar tool. To get the panel off, remove the reflectors on either side and pull straight down. The plastic clips hold very well so pulling hard is needed, but straight down. The electric switch for the tailgate has a slip connector that must be disconnected.
Once the panel is off, there are 6 fairly large torx bolts, 2 on either end and 2 in the middle. These connect the light to the body. Once removed, the light is free. Just disconnect the power and you are good. Putting the light back in proved more difficult. It is just the reverse of the removal, however I could not get the 2 center bolts to align to the point where I could tighten them. Got them threaded but that was it. Seems ok. Will get to check one more time when the new part comes in and I install it.
Will do a quick step by step video.
My wife backed into a tree with our Gen 2 Macan. Broke the horizontal center light. Ordered a replacement from Suncoast Porsche. Install was fairly straightforward. Since she has backed into the same tree for a second time, when I replace the unit again, I will make a short video. Unfortunately Suncoast part is back ordered until 2/15
john981 (01-11-2024)
Thought it was worth mentioning...
PS - you may want to either remove the tree, or the wife
