2023 macan GTS door locking
Hi everyone. Does anyone know if there is a way to make is to when you unlock the car it just keeps all four doors unlocked also? It's very annoying you get out of the car after driving and close the driver door that remains unlocked but then go to get into the back door after closing the front door and it's locked. You have to open the front door back up and unlock the car. Same thing you go to open the passenger door and put something in or whatever and have to walk back around the whole car and open the driver door and unlock the doors from the side panel of the driver door. I would love it if there is an override for this. I've never had a car that does this before.
FYI, my Audis did the same thing. It is a safety feature, so that people with bad intent cannot enter the car from other doors as soon as you unlock, either from the inside or the outside.
My VW Golf R will open the driver's door if you tap the inside of the handle once, and option all doors if you tap the inside of the handle twice. Both my Porsche's do not. Which is dumb b/c they use the same electronics. Anyhow yes you can change this in the PCM settings as said above.
