Replacement Door Pillar Trim...
Seems like an inexpensive solution.
Has anyone gone through this? Easy? Would "professional insallation" be better?
https://www.suncoastparts.com/product/95bdptr.html
Related but got PPF + ceramic coating done on my new GTS and the installed put PPF over all of those trim pieces at no extra charge. Smart move as they definitely get dinged up over time.
I figure it’s an old macan s, not a sweet 911, so mediocre is fine 😂
Based on info here and in another MacanForum, the 4 common options appear to be:
1. Replace - Replace the faded/cracked pillar trim with New trim pieces from Porsche, Suncoast, etc.
2. Cover - Cover the faded/cracked piece(s) with thin, stick-on plastic B-pillar and C-pillar pieces. Here is an example: https://www.ebay.com/itm/126432331509
3. Wrap - Apply vinyl wrap in gloss black, satin black, etc.
4. Ignore - Do nothing and enjoy the "patina"
Has anyone had recent success with option #1 or #2?
This stick-on kit is a low-cost, easy-to-apply, 10-minute option for quickly refreshing the Macan's pillar trim appearance. Although the ebay description states "Material: PC Plastic", the kit I received contained several 1-mm thick vinyl sheets cut to fit each B and C-pillar. These were Not hard plastic sections. The product has a gloss black finish that looks decent from 10-feet away. (If you prefer a satin black look, which I do in hindsight, then simply do not peel off the protective outer plastic film.) But a closer, 10-inch inspection will reveal some issues -- it is a lot thicker than a vinyl wrap or paint protective film, and the fitment is not 100% perfect around the corners and edges. This is clearly seen if you view it close up at an angle.
For the price, this kit provides a huge, instant, short-term improvement in appearance, which would be evident if I had not forgotten to take a few "Before" pics. However, time will tell if the trim pieces are truly durable, "scratch and chemical resistant", and "car wash safe" as the seller claims. If it is showing signs of wear after after a month of daily driving, then I will book an appointment with a nearby Xpel PPF specialist.
Price = Low
Installation = Easy
Appearance / Fitment = Meh
Durability = Unknown
I hope this helps someone else!
Satin Finish (just installed, before removing outer film):
Gloss Black Finish (final look, with outer film removed):
