Macan 2014-Current
Sponsored by: HBI Auto
2015 Macan S
Old Oct 3, 2023 | 09:07 PM
reichspeed's Avatar
reichspeed
4th Gear
Default 2015 Macan S
Looking at purchasing a 2015 Macan S with 86K miles. Car looks great and rides well. Valve train seems a little noisy but not sure if that's mormal. Any advise as to what to look for?
Old Oct 3, 2023 | 11:33 PM
wwahl's Avatar
wwahl
Check for oil leaks around the timing chain cover.Timing chain cover
Valve cover leaks
Transfer case replacement
Cross plastic cooling system
Water pump replacement
Thermostat replacement
PDK replacement
AS problems if installed
Battery replacement
Suspension elements
Brake rotors and pads
Door handle plastic breaking
Any other plastic stuff breaking
Button caps falling off
Needles on instruments falling off
Leaking water into car from plugged drain tubes
inoperable air compressor
failed TPMS
Wheel alignment
Headlight plastic covers cracking
These are the areas that need to be looked at. Get a PPI done. Give them this list.
