Please help! 2015 Porsche Macan Turbo - 255 55 18
Hey everyone. I have researched this throughly before posting but I have a set of winters from my cayenne that I wish to put on my macan turbo.
these tires are 255 55 18
rim: 8Jx18H2 ET53
macan: 2015 turbo
All my research shows it will fit fine but just wanted to confirm.
rim: 8Jx18H2 ET53
macan: 2015 turbo
Why don't you just look at Tirerack and see what their 18" winter tire + wheel package is for your Macan? That will give you the recommended setup that is confirmed to work. Not sure where you did your research but your conclusion is incorrect.
As mentioned above, that offset is definitely wrong as is the bolt pattern. The Macan uses a staggered tire setup so 255 is likely too wide in front. That Cayenne setup won't work.
Correct that the Macan is the only Porsche with the 5x112 bolt pattern that Audi uses. All other Porsche models (except centerlocks) are 5x130 and have been for decades. You cannot cross them over.
