Macan 2014-Current
Sponsored by: HBI Auto
Replaced PCM 3.1 on 2016 - Questions
Old Aug 15, 2023 | 12:16 PM
jpc763's Avatar
jpc763
7th Gear
Default Replaced PCM 3.1 on 2016 - Questions
I had to replace my PCM on my 2016 (3.1) due to a board failure. I swapped the HDD from my PCM into the donor PCM. I added in a CarPlay board and it works as does the AM/FM radio but NAV and SAT do not work (although I did see SAT yesterday). I was told that it needed to be coded to the car with a PIWIS.
What exactly will they be coding?
Thanks in advance
