How Long Are Faults Retained?
I was driving around town one day last week in my new to me but well PPI'd 2017 base Macan. It was a very hot day (100F+).
I got a warning to the effect of check engine but you can still drive (see image below); reseating the gas cap did nothing (it was tight to begin with) but that was the only day I got the message.
How long, if at all, is a fault code such as this retained in the car's computer?
I tried to search for an answer but I guess I'm too wordy b/c I couldn't find it.
Thanks,
--Bob
Thanks,
--Bob
Thanks,
--Bob
Thanks,
--Bob
Thanks,
--Bob
Thanks,
--Bob
1 - sensor notices that issue is fixed (eg. if something is unplugged and it gets plugged back in) - then car is turned off then restarted
2 - manual reset needs to happen (eg. find an ODB-2 / ODB-II clearer - amazon will have stuff like that from 50-200 (depending on how fancy you want it and if it has the capability or functionality))
3 - unhook battery and let it sit there for a few mins (10 or so I would believe would be more than enough YMMV)
you can also go to your local autozone or local car parts shop, they usually have a code clearer that you can quickly borrow for free. plug it in, scan it with the key in the acc or on position (scanner will tell you) and then read and clear it yourself.
Fault codes usually are retained until a few things happen:
Pulling the battery will not reset the monitors even if a code is cleared. OBDII faults are part of the federally mandated emissions control system and the cars are smart enough to retain memory of an emissions fault even if power is removed.
If the fault never returns (the car is repaired or the fault was intermittent) the original fault code is retained in memory until reset by a scanner designed for the purpose. The check engine light may go out and you can drive the car normally, but the fault code is stored indefinitly until reset. If you are in a state like California, the smog stations connect a computer to your OBDII port and if there are any uncleared codes or incomplete monitors, they will not pass the car for smog and you cannot renew your registration. I don't know how many other states are similar (NJ, NY?), but most are not as strict.
There's 4 types indeed:
1. Some codes disappear after re-start.
2. Some won't.
3. Some codes have a counter which clears them automatically after several re-starts (engine off/on), cannot remember it it was 30 or 50 starts.
Special case:
Some of the emission related codes need a certain amount of miles (not re-starts) before they get deleted. If you're too early for emission check, you may fail it as it is a measure to prevent clearing those just before you go through an emission test.
4. Plus. the last 20 warnings showing as text messages in the right dash instrument are stored and can be looked up with Piwis.
2. Some won't.
Special case:
Not quite.
I do disconnect battery for a while. tried it a couple of times - unless it's a fault with legal things (eg exhaust related or fuel related) all items cleared after battery is pulled.
Only major thing I tested:
- the value open/close actuator. and after plugging the actuator back in then battery unplug - scanner said code never existed (also verified that during replug the fault code stayed on until battery pull).
- unplugged a couple of vacuum hoses until fault came on and did the same -- plugged it all back in, validated that code stayed on, pulled battery -> boom gone.
dunno -- anyway it's just based off of my experience.
interesting thing enough - maybe unique to my car. usually power off code resets.
gellenole (08-21-2023)
yah, scanner code cleared before connection -> then reconnected to see if it picks up code -> no codes.
Hopefully not as long as my wife remembers.
mikebrinda (08-23-2023)
If you need to pass emissions inspections (at least here in CA) while ANY monitors are still running, you will fail inspection. In other states they may allow certain monitors to be running and still pass inspection, but which ones and how many are up to local laws.
2. Some won't.
Special case:
2. Some won't.
Special case:
