Macan 2014-Current
Sponsored by: HBI Auto
Radiator shutters/louvers
Old May 19, 2023 | 02:50 PM
ahhprods's Avatar
ahhprods
Default Radiator shutters/louvers
Hi,
How long are the radiator shutters/louvers supposed to stay open once you’ve parked? Thanks!
Old May 19, 2023 | 08:24 PM
VAGfan's Avatar
VAGfan
The Porsche DME algorithm of how the front louvers behave has long been a mystery.....
Old May 22, 2023 | 12:07 PM
ahhprods's Avatar
ahhprods
looks like mine never close, so off to the shop!
Old May 22, 2023 | 04:12 PM
ozziegt's Avatar
ozziegt
I had the same issue. Dealer charged like $1700 to replace the entire assembly - some folks have been successful just replacing the internal motor themselves for a couple hundred bucks
Old May 22, 2023 | 05:24 PM
jhbrennan's Avatar
jhbrennan
I would think temperature control provided by the shutters would be part of the emissions algorithm and if it failed to operate properly, it would set off an ECU error??
Old May 28, 2023 | 01:43 PM
chassis's Avatar
chassis
G01 BMW has a history of active shutters failing and triggering CEL. BMW has a warranty campaign for it including extended coverage for the shutters if I recall correctly. Would be nice if Porsche did the same. This is relatively new tech in the industry and it doesn’t differ substantially between brands.
Old Jun 1, 2023 | 11:19 AM
offagain's Avatar
offagain
I believe so. I had a one-off error on their operation and it bonged on the dash. Kept a message on the display until you hit the back button, but retained the message. Had it booked in to have it looked at and it fixed itself before the appointment. Weird and had the dealer check when it went in for a service later. Their assumption was that it got stuck on a bug or something and freaked out. The logic is supposed to work to keep it open if there is a problem - which isnt the most efficient and hence will impact the emissions.
Old Jun 1, 2023 | 12:37 PM
VAGfan's Avatar
VAGfan
Active radiator shutters are not really new-tech, the Porsche 928 had this back in 1977.
And, as far as emissions, the coolant thermostat and radiator fans are the primary factor in engine temperature control, the radiator shutters are more for better aerodynamics (when full radiator airflow is not needed), for a slight increase in fuel economy.
Old Feb 14, 2024 | 01:20 PM
THE Z MAN's Avatar
THE Z MAN
How does this information differ for the 997.2?
I have a C2S that I am about to install a 3rd radiator. It has a evomSit tune and cat back exhaust.
Thank you
