Porsche Macan PASM dtc 000001 Please help.
Could you please give me some advice? I have this dtc code from PASM.
000001 Control Unit, Cross Installation Or Commissioning Not Completed.
Right now I can connect to PASM ECU to read the code, but I can not run a test on it. It always return "failed" when I submit the test. I tried to turn on the air compressor, but it always reports "connection failed".
I have attached the PASM wiring diagram for this vehicle. I have checked the main fuse and relay and they are fine. Could you please tell me where I need to check this problem?
This car is Porsche Macan 2015.
Best regards,
Best regards,
