Wireless CarPlay not available in certain countries
Basic Sponsor
Recently I have got some enquires from different customers regarding the wireless CarPlay issue, initially, I was surprised and though that was just coding issue for some of older cars with early PCM5 system. However, I was wrong, it is more than I thought.
Such as Japan, 5G band wifi is disabled on all Porsches in Japan market due to the regulation. So the simple coding will not fix the problem. Even for brand new Macan, wireless CarPlay is not available in that Country.
Also found in Brazil, all wifi function is disabled.
For those could not get wireless CarPlay working, you should check two things:
1. Do you have wifi feature in your car
2. if you have wifi, try to use your phone to search if you can see Porsche hotspot with 5G band available.
if you can see the wifi option in your car but you still have no wireless CarPlay, then check from your phone wifi list
check if you have 5G signal
some time normal coding can resolve the issue but for certain countries like Japan, Egypt, Chile, India....etc it will require more for the activation.
If you are in the countries that has wireless CarPlay issue, try to check those two things and if you still have issue after coding, then let me know I can probably help you get around the limitation.
Porsche PCM specialist
imessager /WhatsApp: +6421404548
Skype:song8062
Email:info@innovativesoft.co.nz
Telegram: ClickHere
website:www.innovativesoft.co.nzContact us for discount code
Skype:song8062
Telegram: ClickHere
website: www.innovativesoftnz.com Contact us for discount code
Skype:song8062
Telegram: ClickHere / @innovative_soft
To make order on website please contact us to get special discount coupon code for all forum members
Skype:song8062
I had something similar occur in Germany during European delivery on a 2023 Macan GTS. Wireless car play wouldn't work, the local delivery specialist was stumped. But upon delivery in Canada it magically started working. Quite strange.
