BRAKE PADS with LESS DUST?
We have had luck with both Hawk Ceramic and Carbotech's 1521 ultra low dust compound. I will have to check with Carbotech to see if they have the backing plate in stock, but shoot us a message if interested.
Our experience with low dust brake pads has taught us that when you switch to a low dust brake pad you loose some braking performance.
--Aaron
--Aaron
I think the gent that posted the comment about "giving up some brake effectiveness" means on the braking limit, not initial feel.
I've noticed the grabbiness on OEM Porsche (and Audi) too. This is what I meant in my post above about "pedal feel and linear progression". My 981 Cayman, and now my Macan, both take too little effort just off the stop so that they are a bit hard to modulate in very light braking, but as you increase pedal pressure the braking force increases less and less with the increased force, in other words the friction progression is non-linear with the pedal effort. Both Hawk and Akebono solve that problem: not as touchy during very light pressure, but as you increase the pressure the friction increases at the same rate.
going with ceramic on other vehicles I’ve had an issue with squealing when first stating out, actually it was with ceramic/carbon fiber pads, no issues like that with the pads you’re referring to?
My stupid question: have you looked at Hawk. The manufacturer? Hawkperformance.com? How bout Flat6?
Basic Sponsor
I’ll look these up.
DaveT435 (12-23-2022)
--Aaron
--Aaron
You will probably have to call Hawk to find the right pads. Their website listing is very poor, I don't see the rears listed and some years are omitted for no reason (same brakes). For my Panamera I had to do this. Tirerack was incorrect/incomplete as well. A call to Hawk got it all sorted out.
Need4S (01-07-2023)
Registered User
A little bit off topic, but wondering if I could pick your brains here. I picked up a 2017 GTS as a new DD to keep the miles off my ST turbo. The stock brake performance is a little underwhelming (after intake/AWE exhaust/Cobb stage 2 tune) I was hoping that a set of Hawk pads would remedy this. Everything says I need the turbo pads for the front, but do I order the regular Macan pads for rear? I hate to order and return just to find out so I figured someone else had already made this mistake.
