Random Oil Pressure spike at cruising speed
Hi I'm driving a "22 Macan S, twin turbo V-6 with 4,000 +- miles on the clock. While cruising on interstate at 70-75 MPH, at 2000-2200 RPM, randomly without any throttle input, the oil pressure gauge will spike up from 20-22 PSI and climb up thru all the numbers up to 45 PSI within a few seconds ! Then back down again to 20-22 PSI. No change in RPM or speed while this is happening. Will stay at 20-22 PSI for a few minutes, and then randomly do the same all over again. Odd that I never noticed this on the gauge during the first 3,000 miles or so. Could this be an actual event, or just a faulty sending unit or similar gremlin. If it is actually happening, what could cause this and could it be harmful ?
Dealer looked at it and sees no fault or error codes indicated when look into memory. Weird. Has anyone else experienced this spike with any other Porsche or Audi? Thanks in advance for your advice.
This engine has an ECU controlled oil pump, which can reduce the pressure to reduce fuel consumption (lower pump pressure equals lower oil pump drive losses) when a lower oil pressure is acceptable during certain engine operating conditions. I think the pressure spikes you see are the ECU regularly "excercising" the pressure control solenoid valve. The higher oil pressure is not going to harm anything.....but one has to wonder why the engineers thought that the pressure control valve needs to be checked so often...I would think once per drive cycle would be more than enough!
This engine has an ECU controlled oil pump, which can reduce the pressure to increase fuel consumption (lower pump pressure equals lower oil pump drive losses) when a lower oil pressure is acceptable during certain engine operating conditions. I think the pressure spikes you see are the ECU regularly "excercising" the pressure control solenoid valve. The higher oil pressure is not going to harm anything.....but one has to wonder why the engineers thought that the pressure control valve needs to be checked so often...I would think once per drive cycle would be more than enough!
