Macan 2014-Current
Macan S - 2017 vs 2021
Old 06-12-2022, 10:06 PM
bboerit
bboerit's Avatar
Default Macan S - 2017 vs 2021
Just thought I'd share my experience for what it's worth... After driving my new '21 for 6 months, I offer the following observations:
- turbo delay MUCH more pronounced (and VERY annoying) on the '21
- PCM much worse on '21, for example Apple CarPlay is practically un-usable while car is in motion (beyond annoying)
- transmission shifts much sooner/quicker on '21
- exhaust sound is much less pronounced on '21 (I prefer the more pronounced sound)
- ride seems to be stiffer (same tires/pressures as '17) on the '21 however this may be due to break-in
- otherwise the cars are pretty identical
I still have the '17 and while I've always rated it a 10+++, due to the the turbo delay and PCM issues on the '21 (both big issues for me), I can only rate the '21 a 7.
Old 06-13-2022, 01:29 AM
Noah Fect
Noah Fect's Avatar
Received 1,299 Likes on 886 Posts
On the plus side
- Oil stays inside the engine
Many of the other points you raise go away in Sport+ mode. If your S isn't equipped with Sport Chrono, it could be worth investigating an aftermarket upgrade, or at least a tune.
bboerit (06-13-2022)
Old 06-13-2022, 01:26 PM
CapitalAL
CapitalAL's Avatar
most, if not all of those issues were addressed in the 2022 S. The 2.9L is far more responsive and has a better sounding exhaust. The different PASM modes allow for the suspension firmness to be customized to be softer. The only thing I am not sure on is how well the PCM works.
Old 06-14-2022, 12:02 PM
Blu311
Blu311's Avatar
Pedal commander is a worthwhile upgrade for the throttle response (and turbo delay) issue, sorry about the PCM/CarPlay, maybe have the dealer look at it?
Old 06-15-2022, 11:29 AM
herragge
herragge's Avatar
Originally Posted by Noah Fect
On the plus side
can you elaborate on the oil issue?
Old 06-15-2022, 06:05 PM
alfa63
alfa63's Avatar
Perhaps the potential timing chain cover leak on the 3.0 V6 versus the newer 2.9 V6 was being referenced.
Quick Reply: Macan S - 2017 vs 2021
