Took delivery of my '22 Macan GTS and here are the bad things about it
I picked up my '22 GTS a week ago, my 3rd Macan. Had a '16 Turbo and a '19 S.
This is the best by far. I have the suspension set to full stiff and it is just fine. Steering seems to be improved, has more feel. Engine has considerably more power at tip-in than the S. This is a dandy little car although the Carmine Red is just a bit redder than I would like. The console buttons are too bright so that's probably my only complaint.
secondtimer (06-09-2022)
Is PS+ available on the latest Macan? Definitely worth it on my 992 and easily changeable via PIWIS providing speed dependent steering.
siberian
siberian
Is is settable?
Meaning you can revert to standard or non speed dependent steering if you want? It seems in the 992s the dealer can set this by entering a code in PIWIS making the option appear on your PCM. Since i don't have the code I was able to enable it but not have the option. Meaning if I want to disable I need to change a selection in VOF and then Auto Code EPS.
siberian
siberian
Am I missing something?
Where is the 12v outlet?
Passenger footwell
siberian
siberian
I was thinking of the 992... sorry
siberian
siberian
luv2sleep (06-13-2022)
I miss the joke on the 12V outlet, the previous model was in the same place under a goofy flappy lid.
One in the footwell would be better.
Oh, is this the old pennies dropping into the socket thing? Surely not.
You would really have to try to get a penny into the 12v socket. When not in use it's covered by the rubber mat and I'm assuming when being used there's an adapter in the socket.
