How do you keep Macan tailgate closed when hauling long cargo?
Stupid question: How do you keep the Macan tailgate closed when hauling long items. I need to pick up some fence panels that will stick out the back. The electronic trunk can be closed to just above where the fence panels stick out, but the tailgate will randomly open on its own when driving. Is there a way to get the tailgate to stay partially closed? I considered using a strap to hold the tailgate down, but am concerned that it will damage the electric opener since it seems to want to open itself while driving.
Does anybody have any suggestions?
It might be possible to use a tie down strap of some sort connected to the locking loop on the tailgate then attached to the port and starboard rear tie down points. I hate to recommend bungee and myself would figure a way to use a ratchet strap, but a bungee would work well. I would also use some sort of cushion against the tailgate edge to protect it from friction when going over bumps.
Probably best to pull the fuse.
peterp (05-09-2022)
That seems like a good idea. I'll have to break out the owners manual to see where the fuse box is and to see if there is a separate fuse for tailgate. I wish Porsche had a PDF version of the owners manual for the 2018 -- I find that much easier to use than printed owners manual.
Also recommend running with the other windows open, to ensure you get plenty of fresh air from someplace other than the exhaust pipes.
Running with an open liftgate can lead to CO buildup in some scenarios, which is why the manual warns against it.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
It's like 20 bucks to rent a Home Depot truck etc. Keep in mind one scratch,one damaged tailgate, one cut in the interior, will cost way more to fix than what you could rent something for not to mention the down time you'd incur IMHO.
The following 6 users liked this post by Gary S.:
drcollie (05-08-2022),
MGT3 (05-08-2022),
nevil (05-08-2022),
peterp (05-09-2022),
Terry Adams (05-10-2022),
and 1 others liked this post.
Have done this more than once! IMO, no vehicle can serve all purposes even reasonably well. An SUV is not a truck!
I think you can look up "fuses" in your printed owner's manual and get to that section easily enough.
But as mentioned above, just rent a truck and take the worry out of it. Some stores also offer delivery, might be worth checking out.
If you have a hitch hook up a trailer. I made sure to order my Macan with the hitch option because I do a lot of landscaping and construction work and there is no way I am putting any of that in the interior of the Macan.
Thanks for the feedback. The fence panels easily fit in the Macan, they are just too long. I keep forgetting about the Home Depot truck rental -- I guess I'll do that for the fence panels just to make it easier, but there are times when I want to carry something small that is too long to fit, and I definitely don't what to rent a truck for that (for convenience reasons, not cost), so I'd still like to find a way to keep the tailgate closed in those instances. I did it all the time on the Q5 I had before the Macan, but there doesn't seem like a safe way to do it with the Macan's electronic trunk hatch. I find it really annoying when the newer car (Macan) loses functionality from the older (Q5) car. I'll check the owners manual as others have suggested to see if I can pull the fuse to keep the hatch closed on smaller items.
The height (or size of opening) of the liftgate is adjustable - meaning the point at which it stops opening once you engage it to open. For the purposes of this and other such one-off operations, is it not possible to adjust the stop position lower after which the motor stops opening the liftgate, and then you can safely tie it down with padding to secure it? Perhaps there's a minimum height and so it wouldn't work, but I would try this - assuming the OP wants to still do it this way.
