Macan 2014-Current
Sponsored by: HBI Auto
Engine mount replacement
Old Feb 20, 2022 | 11:37 AM
ozziegt's Avatar
ozziegt
Default Engine mount replacement
Dealer says I need new engine mounts. They quoted 9 hours of labor. The tech said they have to remove some other parts to get to the mounts, and that is why the labor is so high. But I'm looking at the service manual and it looks pretty simple:
  1. Remove wheel
  2. Remove wheel housing liner
  3. Remove underbody paneling
  4. Install engine safety device
  5. Unhook a wiring connector
  6. Remove the mount
  7. Install the new mount
  8. Reverse steps 1-5
Does anyone have first-hand experience doing this? The only issue is I don't have the hanging system for the engine. It is likely covered under my third party warranty and it doesn't look very complicated so I can find a shop to do it, but I am wondering why the dealer wants 9 hours for to do both sides...they also said the bolts need to be replaced but the service manual does not say to replace them.
Old Feb 20, 2022 | 11:46 AM
Faust T.'s Avatar
Faust T.
that looks like it's for the I4 model, for the V6 IIRC you need to drop the sub frame, a few one time use bolts need to be replace,
and also and alignment afterward.
Old Feb 20, 2022 | 12:14 PM
ozziegt's Avatar
ozziegt
This is the 2015-2016 repair manual so no I4. Also it only lists this single procedure, it doesn't have any separate procedure listed for the Turbo
It does say "MACAN" and not "ALL MODELS" so now I am not sure, but I don't see any other procedure. (Other examples like Pressure Loss Test also just say "MACAN" but I assume they are for all models)
Old Mar 13, 2022 | 12:34 PM
mhuraib's Avatar
mhuraib
Hi ozziegt,
Im planning to do that myself as will for Macan S 2015. Faust is correct, the one in the manual is for 4 cylinder engine, and you can confirm that from the engine mount shape for the macan S, it's different than the one on the manual.there are bolts that connect the engine mount to the car from the side and from the bottom, while the manual 4 cylinder one only 3 bolts from the side connecting it to the car.
but my current project is replacing the steering rack, hopefully everything goes well, then I will dive into the engine mounts.
be careful not to order the wrong engine mount number. I was very close to do that. I will share more details later once I dive into it, please keep us updated as will.
Old Apr 1, 2022 | 02:55 PM
Finwiz123's Avatar
Finwiz123
Cruisin'
any updates on the Macan 3.0 L engine mount replacement steps necessary to perform?
would like to do myself. Thanks
Old Apr 1, 2022 | 05:09 PM
ozziegt's Avatar
ozziegt
I am having my mechanic do my mounts. He said they do have to drop the subframe, so that confirms what others have said and the instructions in my repair manual are incorrect.
Old Apr 1, 2022 | 09:33 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Ozzie, how many miles? Any contributing factors to the mount failures?
Old Apr 1, 2022 | 09:48 PM
ozziegt's Avatar
ozziegt
2015 Turbo with 85k miles. I bought it with 57k miles, I don't know if the PO did anything that might have contributed. I think he had a racechip and I have a cobb ap so it's possible the additional power put extra strain on the mounts. But I don't give it full throttle very often. I don't know how the PO drove it. That's the only contributing factor I can think of. Both my Indy mechanic and the Porsche tech didn't suspect it was the engine mounts because they haven't seen them go bad on the Macans. So I don't know if this is a fluke or maybe something that might affect higher mileage ones. It took them 2 days to get one of the mounts so it's not something regularly stocked by the dealers.
Old Apr 1, 2022 | 10:22 PM
NC TRACKRAT
Veteran: Navy
Thanks for the info. Poop happens. When done, please let us know what the actual hours were vs. dealer estimate.
Old Apr 7, 2022 | 09:57 AM
Finwiz123's Avatar
Finwiz123
Cruisin'
Default Engine mounts
Do you know if the passenger or driver side engine mount is easier to access?
Old Apr 7, 2022 | 05:15 PM
PSEE's Avatar
PSEE
I had one engine mount replaced at 3XK miles. I didn't know it was bad. The dealer informed me and it was under CPO at the time.
They did have to drop the front subframe, so it's kind of a big deal.
Old Apr 7, 2022 | 11:35 PM
ozziegt's Avatar
ozziegt
I don't know. I don't know the number of hours the shop charged either, it's not itemized on the bill they gave me.
Old Apr 28, 2022 | 09:59 AM
Finwiz123's Avatar
Finwiz123
Cruisin'
Default engine mounts
Did you have the engine mounts replaced?
if so, would you post the parts and labor required?
Old Jun 29, 2022 | 09:55 PM
SpawnyWhippet's Avatar
SpawnyWhippet
I am installing an engine in my Macan now. The left engine mount has a broken bolt end in one of the holes. I can't seem to find the correct size triple square for the bolt to remove the mount from the engine.
12 is too small and loose and 14 is too large. There does not appear to be a triple square tool in size 13, nowhere I can find sells one. Anybody who has done this know which tool to use?
Old Jun 30, 2022 | 01:23 AM
mhuraib's Avatar
mhuraib
instead of using the inner triple square, you could use the outer hex.
can you please share some images to help with our replacement, and the steps on how to get the left engine mount. it appears to be snug between multiple parts.
I found the following YouTube video if it will help, but it's not very clear on every step, an example he removed the anti-roll bar without mentioning it:
it would be helpful if you can show us your steps and record the reinstallation of the parts by video or images.
would be much appreciated
