30K service
What model/engine? I just had 30K done on a base 4 cylinder 2017 Macan. I cannot give estimated cost as I purchased the 5yr./50K maintenance plan for $3,000 covering five services..
At 30K they did the following:
Oil& Filter Change
Replace Spark Plugs
Multi Point Inspection
At 20K they did Oil & Filter, Cabin Filter, Brake Fluid Change.
At 40K they should replace the Air Filter, and replace transmission fluid as well ($$$$$)
Oil& Filter Change
Replace Spark Plugs
