Carplay and PCM issues
Hi there. Having some issues that are new, I think. 2020 Macan.
1. When carplay is active and I am playing the radio through the PCM, when I activate the voice input button on the steering column stalk, carplay responds but the sound through the PCM doesn't mute or diminish so I have to manually mute it.
2. When I close carplay, the voice input button doesn't respond with regard to the PCM controls.
I have reset the PCM to no avail. Any thoughts?
Honestly, I've never liked the CarPlay integration either on my 2019 Audi Q5 (Lemon) or my 2020 Porsche Macan. I have all of my music on a 32GB SD card in the arm rest and I simply use that. It's easy. For navigation, I use Porsche's built-in system, and it works well enough for me. If CarPlay were a standalone option, that's a box I would leave unchecked.
-James
Seattle, WA
-James
Seattle, WA
Most of the time CarPlay works fine, but every once and a while the PCM won't connect to my phone either via Bluetooth or using the USB cord. It's connected for phone calls but not CarPlay. When it's connected it works very nicely. OP, are you using your voice control button property? When you're just using PCM, you push and release it quickly. When you're using CarPlay, you hold it in. In each case whatever you're playing should mute and the disembodied voice should be easily heard. I never have a problem using voice commands.
993*David (06-27-2020)
Just one issue remains: When you are using the PCM (radio) and CarPlay is active and you do a long press for CarPlay, does the radio mute or dimish to allow a voice command to CarPlay?
