Wireless Carplay no longer works in 2019 Macan
Hi all,
Tl;dr - I had wireless carplay working in my 2019 Macan, after 2 weeks of inactivity, it no longer works. Any ideas on how to fix it?
Mine works fine, Porsche has a lot of issue with the PCM. Give Porsche a call they will work with you or send you to the dealer. My car play does crazy stuff. I'll hang up using my phone and the car stays stuck on a call that is over. It won't change back to XM. I have to disconnect the phone Blue Tooth. It also has issues storing my personal info in the PCM. It's a joke.
I would recommend completely deleting your phone from the PCM device manager and then re-adding it. I would also "forget" the bluetooth and wireless connections from your phone directly as well.
Then reconnect and it will likely fix it.
