Break Fault message and Brake Booster Vacuum
I just got back my 2019 Macan S after Brake Vacuum sensor connection was damaged. Took 2 visits to discover. Repaired well I hope. I got the car back from my dealer and found out they put 20 miles on the car. When asked why so many miles, the Service Adviser explained they took it out twice to set vacuum pressure. Does that sound right? 20 miles??
Ten miles per test trip? That sounds OK, car reaches normal temp, a few hard drives to test on freeway or whatever, return to dealership, adjust, re-test... IMOH I wouldn't be too concerned.
siberian
The best long distance runners eat raw meat, run naked and sleep in the snow
siberian
