Macan Entry and Drive erratic
2018 Macan S with entry and drive intermittent seat issue. Read the owners manual in print and online, stopped by the dealership to have functionality explained, settings 1 / 2 and key stored, but my entry and drive seat settings do not always restore the seat position. Have comfort setting enabled. The doors open properly but the seat does not _always_ return to the setting last stored / used. When the seat does not return to the proper position, I can press button 1 and it will go the the correct position. Doesn't do this with regularity, just often enough to be annoying. Doesn't matter if locked with key or left unlocked in garage, the seat does not return intermittently to the stored position. Does anyone else have this issue / advice?
I've had that happen in my 911 with Entry + Drive, very randomly though and only a few times. I figure it is a minor annoyance so it hasn't stressed me that much.
Come to think of it has also happened once so far on the Macan... perhaps it is a 'feature' in the software code somewhere.
Unique Title
I've also had this happen in my '15, but it's really really rare. I figure it's some stray RF interference or something similar. Anyway, it doesn't happen often enough for me to be bothered by it so I haven't tried to have it fixed.
Have had this happen a couple of random times. I haven't been bothered enough by it to bring it up to my dealer. There's pretty much no way for them to do anything about it unless they can reproduce it and it happens so infrequently.
Here's a link to one of the threads about it in the Cayenne 958 forum. Look at the last post from this thread in particular. Good luck with it! ..... https://rennlist.com/forums/cayenne-...side-door.html
I have the problem with the seat not fully coming back sometimes. However if I push the "key" memory button on the door it will fully restore (mind you this is after I have stored my settings on that button, I'm not sure if that is a necessary step). It's almost like the system stops midway for some reason. Haven't been able to figure out what causes it.
I have a 2015 Macan S with a similar issue, nobody could explain why certain settings were not persistent. I fixed it myself by turning on the automatic save settings function, made all my adjustments, saved to position 1 and key, turned the engine off, then on, and deselected the auto save function. Presto, my settings were preserved.
