Porsche Macan S/GTS/Turbo Stage 2 and Stage 3 Off The Shelf Maps
Basic Sponsor
Are the ridiculous gains offered by only tuning not enough for your Porsche Macan? Wish there were some bolt-on parts to make it even faster? Well, you're in luck! COBB now offers even more potential out of your Macan S/GTS/Turbo! The Stage 2 and Stage 3 Power Packages include new hard parts and corresponding off the shelf maps to take your Macan to the next level!
Stage 2 Power Package
The Stage 2 Power package includes the COBB Accessport and Alpha Intercoolers. With this package installed, you would use the Stage 2 maps that are preloaded on the Accessport. These maps are specifically designed for a vehicle with upgraded Alpha intercoolers.
AMS developed the Alpha Performance Porsche Macan Intercooler System to provide you the best cooling upgrade for your Porsche Macan. The goal was to provide the ultimate system in terms of quality, simplicity, fitment, aesthetic design, and of course, performance.
This system features the highest quality Bar and Plate Garrett Intercooler cores which are a full 43% thicker than OEM! Alpha’s massive cores give you the most power supporting intercooler upgrade on the market. Each of the two super thick 85.5mm Garrett cores provide an optimum fin density of 20 fins per inch for unmatched cooling.
Channeling cool air to the intercoolers is vital for optimum performance of any intercooler. Some manufacturers choose to remove the factory intercooler inlets in order to cut costs. This greatly reduces the effectiveness of ANY intercooler whether it’s larger or not. Others require that you cut up and tape the factory shrouding to the intercooler core in an attempt to seal the shroud to the intercooler core. While this is better than removing the shroud, it is still not the most effective way to boost performance. Alpha’s Engineers came up with the ultimate solution.
The Alpha Performance Porsche Macan Intercooler System features rigid, OEM-quality, carbon fiber ducts designed to mate seamlessly to the intercoolers feeding them cooler ambient air more efficiently than the alternatives. Each organic shaped carbon fiber duct is not only highly functional and designed with performance in mind, they are aesthetically striking as well.
To further improve airflow, the AMS engineering team went a step further by computer designing precisely molded, custom silicone couplers. These provide perfect fitment and optimized geometry for improved airflow volume and velocity providing horsepower gains and quicker boost response helping you stay ahead of your competition! Perhaps the best feature about this intercooler system is that it maintains cooling efficiency as more power producing upgrades are added to your Porsche Macan! It improves the effectiveness of your other upgrades giving you maximum hp output potential! Check out the Stage 2 power gains below for each trim of the Macan.
The Stage 3 Power package includes the COBB Accessport, Alpha Intercoolers, AND Alpha downpipes. With this package installed, you would use the Stage 3 maps that are preloaded on the Accessport. These maps are specifically designed for a vehicle with upgraded Alpha intercoolers and Alpha downpipes.
The Porsche Macan’s two factory downpipes are extremely restrictive. AMS designed the Alpha Performance Porsche Macan Turbo downpipes to expel the large amount of air the Alpha filters were bringing in. They utilized the Solidworks Software program to design less restrictive transitions for the hot exhaust gasses. The creation of smoother organic transitions allows exhaust gases to flow more efficiently which lets your turbos spool quicker, delivering more power, faster. The Alpha Downpipes’ over 76mm diameter is 44% more area than the stock 63.5mm stock downpipes. With the end user in mind AMS Engineers designed the downpipes to bolt to OEM location with no cutting, drilling, or 02 sensor wire extensions. The Alpha Downpipes also were designed with heat management in mind.
The Alpha Downpipes also feature laser cut heat shielding and a high flow Gesi catalytic converter which increases flow without compromising emissions or producing a check engine light. If you have ever been under the hood of a modern automobile you know the amount of unused space is next to nothing. Heat management, therefore, is a major concern. The Alpha Performance Downpipes give you piece of mind that any critical components in the engine bay will be protected by our custom laser cut heat shielding. Check out the Stage 3 power gains below for each trim of the Macan.
Already have an Accessport but still want these awesome upgrades? These parts are available separately without having to purchase an entire package. Once you have the parts installed, simply update your Accessport's firmware to have access to the Stage 2 and Stage 3 maps!
Alpha Performance Intercooler System for Porsche Macan S / GTS / Turbo 2015-2018
- Tough Bar and Plate Core Construction
- Two 43% Thicker, High Quality Garrett Intercooler Cores
- Organic shaped endtanks that allow for smooth transition delivery of charged air flow
- Larger core reduces restriction through intercooler allows for faster spool up of turbo earlier in the power band.
- Custom silicone hoses and carbon ducts that provide OEM type fitment, no cutting, drilling, fabricating needed.
Alpha Performance Downpipes for Porsche Macan S / GTS / Turbo 2015-2018
- Bolts to OEM location with no cutting, drilling, or 02 sensor wire extensions.
- High flow Gesi catalytic converter increases flow without compromising emissions.
- Alpha Macan Downpipes can be installed without removing manifolds.
- Laser Cut Heat shields safely keep heat from unibody.
- Organic castings maximize space and reduce bends that hinder exhaust gas flow.
PORSCHE EXPERT GROUP - TIM | GRANT | HJ | ANDREW | JARED
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE |CONTACT US
I was about to buy your downpipes a few months ago, so I downloaded the installation document. Step 1 changed my mind. It’s not your fault that installation is so involved. I personally don’t feel like pulling a drivetrain at home, and I didn’t bother getting a quote for someone else to do it because it’s ceryaibly obscene.
