DIY - Front/Rear Brake Pad
2017 Macan GTS with steel rotors. So I got a brake pad wear warning light. Anyone have information on the caliper bolt torque requirements for the fronts and rears?
FWIW - a 2017 GTS and you're getting a 'brake pad wear' warning already?!?!
you live on top of a mountain?
go to driving schools frequently?
drive with one foot resting on the brake pedal while the other one is on the gas pedal?
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Unique Title
My manual says the torque spec for the bolts is 118 lb-ft. It's on page 303 with the instructions for jacking up the car and changing out a tire.
Unique Title
Sorry, my misunderstanding. Years back when I did a rotor replacement on my Boxster, I just called the SA at my dealer and asked him to look it up for me. I'm sure it's in a tech manual somewhere but as the brakes on the Macan are essentially Audi parts I wouldn't expect the torque spec to be the same as on other Porsches.
