car numbers for DE
car numbers for DE
Hello all!
I'm new to the DE events, and have one coming up in April. I have a Boxster, and was thinking about getting some magnetic numbers. A few questions for the more seasoned veterans:
1. Are magnetic numbers a good idea? I have read about them coming off
2. Any recommendations on where to get magnetic numbers or vinyl if I go that route?
Thanks in advance for any help, and I apologize if this is posted in the wrong forum.
If you want something easy to remove and is reusable, I prefer window cling. Check these guys out:
https://www.trackdecals.com/
Magnetic numbers can scratch your paint, and potentially come off. Here's what I do: I bought two magnetic numbers to use as a template. Place them on some contact paper in your color choice, trace the number on the contact paper, cut it out, apply to your car. Easy to remove after the weekend. Easy to make new ones for the next DE. Looks professional and inexpensive to boot.
Cheers.
Cheers.
I used magnetic numbers for years with no problems before I started racing. They do not scratch paint. Get a 'permanent' number assigned by your PCA region, and have that number made as a meatball (one for each door). Put a 2" piece of painter's tape at leading edge to ensure wind doesn't get underneath and cause it to peel off during a session (but I never had that happen).
I've used magnetic numbers for 14 years with no problems. I always wipe the car off first, then wipe the back of the numbers off and stick them on the car. If you wipe both surfaces off prior to applying, it should minimize the potential for scratching. Now, after you do this you have to put a strip of blue painters tape on the leading edge of the numbers. This prevents the air from getting under the numbers and they stay on fine. When I first started HPDE all clubs pretty much required real numbers. Now I see lots of clubs accepting folks using blue painter tape for their car numbers. I went to a local company that made signs and they also made magnetic numbers and I got them made there. Make sure your doors are magnetic!
A good quote I have heard from a DE instructor..."Nothing you do today will increase the value of your car." LOL.
Ratchet1025 (12-25-2019)
Received 4,068 Likes
Car #'s
Hello all!
I've tried magnetic #'s and and as others have said you need to tape down the leading the leading edge and it ca't hurt to tape down the a few sides. I've lost my share of magnetic track #'s.
I've been using the static cling vinyl numbers now for years.
They never come off but they are certainly not reusable.
This. Track activity will not improve the paint on your car...anywhere. The surface under a magnetic number is the least of your worries on the track if you are concerned about keeping perfect paint.
I bought a roll of white reusable vinyl from AMZN; stays put and easy to remove. Cheap enough to toss after each event.
I print numbers in Photoshop onto white sticker stock from Walmrt that goes thru my inkjet printer, then I stick onto vinyl, trim, apply. (The vinyl I selected will not take ink from inkjet printer...)
Previously I purchased magnetic meatballs to avoid the blue tape, but needed blue tape to keep in place. So they now decorate the garage fridge.
I bought static cling numbers that stick to the inside of the windows. Reusable. Works great.
PET (09-16-2021)
Hmmm............thought numbers had to be visible on doors and rear????????????????
Usually front and both sides of car is a minimum; at times a fourth placement on rear of car as well, depending on region / organizer.
