Forgive me fellow turtles, I screwed up....
You can hit a 'good' arc through a turn, and hit the apex and track-out nicely, with differing turn-in points. If you turn in later, you'll have to have a more 'decisive' steering input; if you turn in earlier, your steering input will have to be more gradual.
I spent the whole weekend urging drovers to have a more decisive turn-in at T8 & T6. T2, OTOH, requires a gentle initial turn-in, followed by the addition of more & more steering input as you progress through the first 1/2 of the turn (ie, from turn in to apex).
At turn in for T2, I was working on not braking so much, but just breathing on the brakes at turn in and then turning in gradually. But it seemed like more than half the laps, I had a car in front of me there at turn in for T2 that braked hard which forced me to. But when I was clear, it felt good.
The other thing that took some finesse for me is the rolling on of progressively more throttle through T2/T1 as you unwind onto the banking to hit the banking fast. To do it fast requires some faith in the lateral stability of your car as the g forces build through T1!
The Penguin King
The Penguin King
Here's some Zen for you:
RIP
RIP
The Penguin King
I read reel gud wen i chuze two.
When I was racing the 1.8 backward (CW), I'd turn into 11 and then stand back on the throttle. Drive far into the carousel, stand on the brakes, and then trail off the brakes & turn down towards the curbing.
Only thing that makes me nervous there is if people have too sharp an approach angle to the oval. If you lose the back end of the car at that angle, it's possible to go ALL the way up the banking & hit the concrete wall at the top. So staying a bit more to the inside (while rolling in the throttle) keeps you at a more oblique angle to the scary concrete.
Turns like T14 CW (and CCW) have no margin for error - you have to hit your turn-in mark precisely.
Moderator and 993 whisperer
From: At the track. I reside, however, in Navarre, FL.
***You, my dear sir, will never know for sure. Bwahahahah.
Actually, I am starting to run more of a flaxen color, so maybe I should just shut the hell up.
Here is a funny for you all . . . the other night I pointed out to John that my hair is changing colors -- from dark blonde (used to be a 'toe-head') to now getting more platinum. I for a while would use that temp dye stuff to keep the silvers out, but quit about six months ago. John said, "It makes you look distinguished." Grrr. . . I reminded him that was a comment for MEN, not women.
What shall I do with him folks??? Lol.
The Penguin King
