:roflmao:
#46
Hi JoAnne,
Sorry about the delayed reply (this IS the HWFRM Forum though...
) I was intrigued by the bullwhip avatar, so it took me a bit to reply... Interesting flight of the whip...? Can't make out who is slinging it..
Hmmm - anyway....
Thanks!!!
JD
Thanks!!!
JD
#49
Wow! Rennlist must be in its "twilight years" if it gives us knuckle heads their own forum. Just kidding. Phil stole my idea of a first post here, but he forgot
What is the best oil?
Can I fit these ___ tires on my 7 inch rims?
or my fav What are the best tires/rims/brake pads (pick your choice)
I am now going to pm ColorChange and tell him we are up and running.
Someone track down DJ & EJ and tell them we "Made it"!!
I guess I can stop hanging out on Roadfly now
#57
The thinner the better. It will allow your engine to rev faster, as thinner oil, obviously - has less resistance...
Yes - in fact - I'd try 18" rims on the rear and 16" on the fronts. It will help on the understeer on left handers and oversteer on the right handers. I'd also suggest starting at 44PSI on your steel belted radials...
I don't use brake pads. The pads only add to unsprung weight....
I KNOW, I KNOW - Barry Manilow..!!!
Welcome back......
JD
Welcome back......
JD
#60
Only if you know I was kidding about the oil, pads and mixing rims/pressures.!!!!! (<---my disclaimer so NO ONE ACTUALLY TRIES IT AND SAYS "Hey - I read it on Rennlist
Barry Manilow... OK - I think I got that one, 'tho..
Seriously Eric - Welcome back!!
JD
