Sponsored by: APR
factory euro clubsport roll bar for GT4
Old 05-23-2017, 11:28 PM
tcsracing1
tcsracing1's Avatar
Default factory euro clubsport roll bar for GT4
for the man who has everything...
http://www.ebay.com/itm/Porsche-981-...FZEJEr&vxp=mtr
Old 05-24-2017, 04:20 AM
Viperguy324
Viperguy324's Avatar
So Hawt
Old 05-24-2017, 12:15 PM
Dr.Bill
Dr.Bill's Avatar
Interesting. Where do the harnesses attach with the Clubsport package? Certainly not to that roll hoop.
Old 05-24-2017, 01:35 PM
Errsomeone
Errsomeone's Avatar
Anchor points in the firewall.
Old 05-24-2017, 01:38 PM
paradocs98
paradocs98's Avatar
$5k. Yikes. I guess an exclusive part can dictate its price. Call me crazy, but I wonder if the roll hoop's attachment to the bulkhead as done by BBi and Cantrell is actually a safer, better design than this OEM Euro part that attaches to the floor structure.
Old 05-24-2017, 01:39 PM
HelpMeHelpU
HelpMeHelpU's Avatar
Wow--nearly six grand delivered. It's about 2X most other bars.
Old 05-24-2017, 06:00 PM
Sven76
Sven76's Avatar
Most proper roll bars - even aftermarket like Wiechers or Heigo- are attached to the floor. I was wondering all the time whether I would trust a bar which is attached to the bulkhead...
Old 05-24-2017, 11:25 PM
ML///
ML///'s Avatar
I think the harnesses bolt to the engine wall behind the seat.
Old 05-25-2017, 01:09 AM
Alpha.GT4
Alpha.GT4's Avatar
Harness is attached to the firewall wiry cutouts from factory
i would argue without actual data that mounting to the floor is far superior than doing so to other areas that aftermarket bars go into. The factory bar is attached to a reinforced block rather than merely thin sheet metal
Old 05-25-2017, 08:29 AM
d00d
d00d's Avatar
Brackets need to be fabricated in order to attach this.
I doubt they are available separate from the BIW from Porsche.
Looks like they fit into a cutout and are welded from underneath.
Name:  90929d1461765756-gt4-clubsport-harnesses-fire-extinguisher-install-13120351_1065608773500823_174.jpg
Old 05-25-2017, 11:58 AM
stout
stout's Avatar
Received 1,301 Likes on 604 Posts
^ Tracks exactly with what I've been told, d00d.
Same source suggested the welding required for those mounts is either difficult or essentially impossible due to use of differing metals at those locations as well as things nearby you don't want to get hot. Will be interesting to see if all of that is accurate—I mean, there is someone converting a 991.1 GT3 RS from PDK to manual right now...
Old 05-25-2017, 04:42 PM
d00d
d00d's Avatar
Yeah, if someone could just come up with a bolt in bracket, then we'd have something.
Then one could obtain the CS package roll bar from a wreck, or in this case possibly a theft, as how do you total a car without scratching the wheels?
Maybe someone could also duplicate the roll bar, and sell it along with the bolt in brackets.
Another benefit, in addition to having the best structure, would be that the factory CS package plastic trim pieces could be used instead of the less than perfect cutting that's required.
Old 01-05-2023, 12:40 PM
Stephen Shi
Stephen Shi's Avatar
The reinforcement plates for should belt mounts and lap belt mounts are riveted into the car body, only brackets required welding is the ones to mount the half roll cage to the floor. Submarine belts mount may just be rivet nuts. If there is any reinforcement structure under the submarine belts mount then it will be difficult to retrofit it.
Alpha.GT4 (01-05-2023)
Quick Reply: factory euro clubsport roll bar for GT4
