GT4 Transmission Failure "Database"
Old May 17, 2022 | 12:03 AM
  #541
Milksteak's Avatar
Milksteak
Originally Posted by HelpMeHelpU
There was ample talk on RL about this topic and I would NOT drive the car in that condition. It's not worth screwing up something worse. Mine failed and I drove it about two miles and then had it flat bedded to the dealer.
You might damage the transmission. /s
Last edited by Milksteak; May 17, 2022 at 06:25 PM. Reason: Sarcasm clarification.
Old May 17, 2022 | 10:42 AM
  #542
OpenWheelFan's Avatar
OpenWheelFan
Nah, if that were the case why would my Porsche dealer send a driver out to motor the car back to the shop? Are you worried you're gonna damage the transmission? It's being replaced !!!
Depending on how spirited the car has been driven, you might consider a clutch replacement whilst everything is unbolted. I did and essentially saved the cost of labor.
Good luck.
Old May 17, 2022 | 11:22 AM
  #543
HelpMeHelpU's Avatar
HelpMeHelpU
Good luck.
There were real stories here on RL that spoke about serious issues, starting with the tranny but not ending there.
Old Jul 11, 2022 | 07:31 PM
  #544
patriot993's Avatar
patriot993
Quick update - Kings Porsche in Cincinnati took care of me - though took a little while to get the transmission. All covered under warranty. I put in a new clutch as no labor charge while car apart. Couldn't be happier with the service and support!
Old Jul 15, 2022 | 05:20 AM
  #545
GT4Frank's Avatar
GT4Frank
Is it possible that a car who had the recall done but not show up on carfax ?
Old Jul 15, 2022 | 08:50 PM
  #546
HelpMeHelpU
Anything is possible. CarFax is far from infallible. It's only as good as the data it's provided.
Old Jul 21, 2022 | 06:48 PM
  #547
Flexipino's Avatar
Flexipino
Posted in wrong thread
Old Jul 30, 2025 | 10:39 PM
  #548
yak52pilot's Avatar
yak52pilot
Default 2nd gear grind
Username - yak52pilot
Date of manufacture - circa 2021
Total miles - 16000
Number of track days - all but break in
Estimated track miles - 14000
The failed gear - 2nd gear started grinding on pick up. Dealer blamed clutch, but clutch turned out fine - so they replaced transmission. Zero issues and free of charge.
Brief recount of the failure - drove fine but occasionally grinds in 2nd
Tires - cup2
Other relevant info - stock except for alignment
Old Jul 30, 2025 | 11:52 PM
  #549
HelpMeHelpU
Total miles - 16000
Tires - cup2
Are you saying you have a 718 GT4 with a failed transmission (3rd gear)?
I thought the failures were limited to 981s built between Nov/Dec 2015 and Sept 2016.
