Rear Toe Issues
Thanks for the info. Funny--I felt the rear to be a bit unsettled under braking at LRP, and VERY unsettled under braking coming into T1 at NJMP Lightning (someone else specifically mentioned Lightning, but can't remember who it was). And yet, at the Glen coming into T1, which is downhill and would theoretically worsen this issue with increased frontward weight transfer, the car felt stable and planted. I was surprised.
I'm running -2.4/-2.0 camber, Tarett caster pucks in front for stock caster (8-8.5), and Tarett rear toe links. I'll have to look at my alignment printout to check the exact amount of rear toe-in.
Has anyone actually spun as a result of the rear end wiggle under hard braking? Or should we assume that if someone doesn't bother added more rear toe, they will just have to live with a dynamic rear under hard braking conditions?
6mm of toe reminded me of the factory spec my 91 NSX had . It ate tires to the cord in 3000 miles of street driving. There was actually a class action law suite started. I backed off the toe to 3mm total and got about 9-10,000 off of the rears. it was a little lose but worth it.
On my new GT4 im running .154" =3.88mm total toe . i ran .078 = 1.96mm total on my first GT4 and it felt OK the two times i tracked it but i was driving at 6-10ths getting a feel for the car .haven't tracked the new one yet but it seems to rotate easier(maybe my imagination) with the same camber as my first one -1.9F -1.5R and bar setting F-m R-full stiff
http://www.nsxprime.com/nsx-faq/tire...els/alignment/
People often overlook how powerful running more rear toe in is for settling down the rear end under braking. Remember that the bumpier the track the more the toe changes as it goes through bump and droop. When you can't run rear monoballs and don't have an LSD, adding rear toe can give you the stability you need. I wouldn't be too concerned about the rear toe for tire wear as the additional static negative camber you're running will have more effect on premature/funky wear than the toe will. The camber will have a greater effect on uneven wear than the toe.
Of note, I believe that our GT4's are the only "GT" branded cars PORSCHE produces that do not have adjustable rear toe links ... Going to race the fastest thoroughbred horse in the Kentucky Derby but, oh yes, I will have to hobble his rear legs so he can't outrun the others ... nice analogy don't you think?
Actually 996-997 GT2's, GT3's and RS's aren't factory equipped with adjustable rear toe links either. In the 997-series street cars only the 4.0 and GT2RS have adjustable. 991 GT3 doesn't. However, the factory rear toe eccentric on the rear-engine cars do have a better range of adjustability. But many people replace them with aftermarket adjustable rear toe links anyway to improve performance and adjustability. It seems that replacing the rear toe links with an aftermarket adjustable version on rear-engine car is more accepted.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
