B4 & after
GT3 player par excellence
^ yes, really good
someone asked how to intall
1 three screw along front edge of rear fender lip
2 slide the door sill out
3 few clips under the door sill that u take out by hand
4 pull side skirt out a bit, align the mesh, has two holes , drill through the two holes (will be self evident once you get here). you drill on a piece of blk plastic on the vent intake, not the actual body panel. dont freak out
5 put everything back on
Would be possible to create a screen that would connect to the stock horizontal bar that you see first when you peer into your side scoop? I just hate the idea that it has to be screwed in, making new holes. Perhaps zip ties will for holding it in place?
From: Québec, Quebekistan, Magic Kingdom of Trudeauland
Where did you source these, mooty? I've been looking for a grille insert like this for some time. My side intakes ingest little twigs and pebbles and the car sounds like a wood chipper as the debris hits the cooling fans.
I emailed GMG to see if they could work on something and no response--*crickets*...
Looks like Bird's nest Soup.
wrap: i thought you were talking about chinese food : lumpia...
well, yes, sills needs lots of clear wraps.[/QUOTE]
Lumpia is a Filipino dish. Do you like Lumpia Shanghai? How about "Fresh Lumpia"? For the benefit of the readers, Lumpia is the term for "Egg Roll" Philippine style.
Drive safe,
GT3RS-Fan1
lumpia is filipino but taiwanese has that, it sounds the same "lumpia" and is so called in enligsh, but it's not egg roll, quite different. my sister used to make them, now she's married a fkg loser so i havent had any lately.
Drive safe,
GT3RS-Fan1[/QUOTE]
next week before thursday, u let me know and i will be there.
