Difficulty downshifting from 3rd to 2nd gear at the track
This happens to me if the car is loaded, like dropping into 2nd going into T15 at COTA. Try shifting while the car is not loaded. If the transmission is in twisted into a different position, it seems to change the position/gates of some of the gears through the linkage. This was a really big problem on the 997 GT3. Stiff/solid transmission mounts fixed the issue. In our case the main mounts are shared between the engine and transmission, so it would add a lot of NVH if we swapped out the magnetorheological mounts for stiff units.
Never had it happen on the street, and the problem only started about 3 trackdays ago, and seems to be getting worse.
Perhaps more of a problem as the mounts wear?
I have a video of Andy Lally almost money-shifting my old RS at TWS going into Turn 1 CCW.....that's when I got bushings. I figured if it's just happening to me, then I need to learn, but if it's happening to pro, then there is a design/engineering issue that needs addressing.
Just came back from a two-day DE on a very tight, twisty track (Shenandoah is 2.3 miles long with 16 corners). Did not have any problems downshifting into 2nd, although most of my downshifts were done in a straight line as I entered the corners. This was my second DE in the car, and didn't have any problems in the first one, either. I now have nearly 4K miles on the car.
Interesting - so I was at Road Atlanta last Friday for a track day. At turn 10A (left turn) coming in hot - hit the brakes and then shift from 5th to 3rd. Then down to 2nd right about to turn - I hit a lock out several times - may have just started to turn and then had to go back to 3rd. It was very unnerving with cars behind me and losing so much speed. After that I just stayed in 3rd and didn't bother with 2nd on that turn. On turn 7 - sharp right turn I had no issues shifting from 3rd to 2nd.
So - I know that the best practice is complete shift before the turn and it appears that at least a hard left there is a shift related to G's that can cause a lock-out and inability to downshift.
Hello,
Anyone have a solution for this issue? I have a 2022 718 GT4 and ran into the same problem on a recent track day at Laguna - under hard braking entering turns 11 and 2, the car refused to shift down from 3rd to 2nd, and just as described, it felt like it was physically blocked. As soon as I exit the track, the downshifts resume working. I am very sure I didn't get into the reverse gate as that has a distinctive click. I tried to reproduce it on the street, but wasn't able to.
Hello,
gvk42 (08-17-2024)
Yeah, any time I experienced this in the past it was because I was pulling the shifter too hard to the left. Since reverse gear is over there, it's possible to pull it past where it will slide into 2nd. It can be an adjustment if you're coming from a car that has reverse on the right side or has a lock-out.
gvk42 (08-17-2024)
I do plan to go back to the track soon and focus on my shifting to see if that fixes the problem I am facing. I am new to this car, so driver error is definitely likely, but I have doubts about both the theories:
- My previous car was a Lotus Elise that had to be shifted precisely, so I always go down->left->down to get from 3rd to 2nd. I have a video of my shifting from the last time I visited Laguna before I started facing this issue (unfortunately I wasn't recording when this happened), in case it helps taking a look at the technique:
- I am pretty sure I wasn't getting into reverse. After I came back from the track, I tried on the streets to recreate this issue. Pushing far enough left to get to reverse, there is a clear click before it goes that far left. I can say with some confidence that didn't happen on track, at least not every time I come to the same corner. Also, when it jammed, I was coasting on neutral trying to get it to fall into 2nd with different motions and it didn't help. If I tried going less to the left, it fell into 4th. And literally within 30 seconds when I exited the pits, it fell into second again.
https://www.youtube.com/watch?v=NNSupXIjlFY
Hello,
for those corners I just push slightly less to the left to grab 2nd and more downwards. It’s more vague feeling for sure.
I also used to have a lotus Elise. But I changed all the mounts to 60a durameter. They shook the car like a massage chair at idle but the shifting was consistent regardless of the load.
I installed Tarett/Wevo Semi Solid Transmission Mounts (2 @ $!69 ea) a couple of years ago. The car is instantly more visceral, with no sign of this 2nd gear issue. Daily drivers won't like it.
Wanted to give an update here. I went back to Laguna Seca a few weeks ago and the advice I got here from @GT4_Rick , @Nate Tempest and @vantage was spot on. Personally, the technique change that worked to get from 3rd down to 2nd was to stop going down->left->down and instead doing more of a diagonal movement. I guess the main issue was I might have been yanking too hard on the left movement... Regardless, moving less to the left fixed it. Appreciate the help in this forum because of which I tried changing technique instead of taking the car into a workshop. @Scott O'Connor I might still try the Tarett semi solid transmission mounts since I care more about track feel, especially at that price! Thanks for sharing your experience.
The following 2 users liked this post by gvk42:
GT4_Rick (08-21-2024),
Nate Tempest (08-17-2024)
