Cargraphic Headers. Whose got em?
#646
Mine are Cargraphic Sport headers, so they have cats. The little nodules have been there since the first few track days after getting the headers coated. The flaking is new. It's not the most visually appealing, but as long as the heat shielding function of the coating is still working, I'm fine with it.
When the coating flakes off like that, in those places there is no heat shielding.
#647
From: On a pygmy pony over by the dental floss bush
Are we sure the coating has completely flaked off there? If it was completely gone, wouldn't it appear more like the bare stainless steel you see on the collector in that photo? Mine don't look exactly like Aualexa2's but in a few places show some discoloration. I don't feel much thickness change where the discoloration has occurred. The coating is around .010 to .015" thick nominally so if it were gone completely, that would be easy to feel with bare hand.
#648
At the upper left of the frame the crack between the coating and the metal can be seen more clearly.
#649
Yeah, I saw that flake, but the darker gray surface underneath doesn't have the texture of the bare stainless steel tubing so wondering if that indicates only a surface layer of the coating has come off. Or does the bare stainless tubing have its appearance and surface texture altered by application of the ceramic Swain coating?
#650
The area could be scratched with a screwdriver to see if it looks like a bare metal scratch or not.
#651
Here's a link to stevencr's FS ad for his headers. I have no relation to him, but checked out his post when he responded to this thread. He has the same flaking (mine look like bigger flakes have come off) and Swain told him the coating is still effective.
https://rennlist.com/forums/parts-ma...l#&gid=1&pid=4
#652
As a test, the coating can be scratched with a screwdriver and it will look like a crayon mark across it's rough surface, where scratched metal will instead be a sharp line.
#653
Before I start scratching stuff, I'll wait and see what swain says. I know they told Stevencr that his coating was fine, but I figure I'll ask them myself. I've sent them two messages through their contact page, and I'm waiting to hear back. Will update when I get in touch with them.
#654
In my initial message through Swain's website, I asked them if there was an email address I could send a picture to. Below is the response I received. I've sent the photo to the email address the message came from, but no further response.
"We have one coating for exhaust parts which is primarily an external coating called White Lightning. It is an ugly coating which mars easily in normal shipping and handling, can be difficult to keep clean and can change color and appearance when in use. There are times some folks will see spike like growths on the surface of the coating and even times when the outermost layer can fracture. When the look of the coating is important our coating is not a good choice. When maximum heat insulation is important it is a great choice. If you are trying to manage heat and the look of the coating is not critical our coating is a great choice. It certainly is possible the outermost layer could fracture and peel."
