Sponsored by: APR
Quick Teaser - Cantrell Rollbar Install
Old 01-28-2016, 10:26 PM
ShakeNBake
ShakeNBake's Avatar
Default Quick Teaser - Cantrell Rollbar Install
I dropped off some tires and goodies from bgb and fabspeed this afternoon, and had the opportunity to take some pics of the work in progress. It's not quite done, but I had to share how it's looking so far.
ATX Autosport in Austin is doing the install - and it looks like it came from the factory this way. These guys have OCD and the skills to make it work, they are by far the top shop in Austin, and even Texas when it comes to this stuff. They had an upholstery shop do the passenger side passthrough so that I could get 6 point belts for the passenger. I used cantrell sub-belt mounts and silver Schroth profi GT3 harnesses. My thoughts process was for the SBM painted bar to match painted interior trim, and silver belts to match the silver stitching.
I went with a cantrell bar for a few reasons. 1) it's one of the few to be positioned as an actual roll bar. 2) I believe, after looking at how the other bolt in units interface to the car body, that it has the most solid interface with strong points in the car I've seen outside of welding it into the car. 3) The harness bar is at a height that supports the correct belt angle for my size. 4) ATX has a lot of experience with Cantrell, and I trust them. If you live in Austin, this is the best setup in my opinion - but if you don't have someone you trust to do this install, since it's more invasive than the other bars out there, it might not be the right solution for you.
I should have better pics of the install once the shop gets a chance to send them to me.
Old 01-28-2016, 10:48 PM
Drjimh
Drjimh's Avatar
Looks great, What belts are those? i would also like to use Silver Belts.
katmeho
katmeho's Avatar
Looks wonderful! Quality part and quality work.
Old 01-29-2016, 10:19 AM
ShakeNBake
ShakeNBake's Avatar
You know, I don't actually know. I assumed they are the Schroth GT3 Profi belts, but they don't seem to sell them in Silver. I suspect this was a custom order to get silver, but essentially the GT3 belts in terms of anchors. ATX figured it out for me.
Old 01-29-2016, 10:27 AM
Jimmy-D
Jimmy-D's Avatar
Received 1,454 Likes on 758 Posts
What other goodies were dropped off??
Old 01-29-2016, 10:34 AM
f4 plt
f4 plt's Avatar
Question I have posed to all that put a roll bar in a Cayman is does the cross bar brace restrict access to the engine compartment ?
Old 01-29-2016, 10:42 AM
STALKER99
STALKER99's Avatar
Great looking set up.
It the bar I would choose as well. Install looks very clean.
Old 01-29-2016, 12:39 PM
Errsomeone
Errsomeone's Avatar
Cannot speak for every bar but the Cantrell cross brace can be removed for servicing. There are bolts at the top and bottom so that it can come out without trouble. If you call they can send more pics as they took closer detail shots of these joints when I placed my order.
Nice looking install. I selected Cantrell as well, now just awaiting for it to be completed and shipped.
Old 01-29-2016, 01:55 PM
electron mike
electron mike's Avatar
The bar looks great and that is a very tidy installation! Do you lose any seat travel? It looks like very little is lost.
Old 01-29-2016, 02:16 PM
JeanKTV
3rd Gear
JeanKTV's Avatar
Can you provide pictures where they cut the carpet
thanks
Old 01-29-2016, 02:29 PM
ShakeNBake
ShakeNBake's Avatar
Bingo - the cross bar is easy to remove, there are bolts on both ends.
No seat travel impact, the bar is no where near the seat.
thanks
All the places the car was modified are in those pics. There were 4 holes cut in the carpet, and 4 holes cut in plastic trim. As to where exactly they are cut, ATX said it was a bit different for each of the 5 981 bars like this one they installed.
Old 01-29-2016, 02:33 PM
ShakeNBake
ShakeNBake's Avatar
Old 01-31-2016, 07:51 PM
Colin - Cantrell Motorsports
Colin - Cantrell Motorsports's Avatar
Great looking install! ATX did a good job.
Old 01-31-2016, 08:10 PM
okie981
okie981's Avatar
Location: On a pygmy pony over by the dental floss bush
Looks great, like the color match to exterior.
Old 01-31-2016, 09:55 PM
zmon
zmon's Avatar
Looks awesome! thanks for sharing. i know we will see when its finished, but you have LWB?
Quick Reply: Quick Teaser - Cantrell Rollbar Install
