LWB Question. Doesn't slide forward enough? Adjustable rails?
Even wearing a mid-weight jacket while driving will provide enough additional padding to make me notice the difference in reaching for clutch.
Mr. Nurse, a possible solution might be to add padding to the bottom vertical portion of the LWB and then put the seat pad back on. This is similar to those that have added lumbar support cushions. When the top layer of the cushion goes back on, no one will notice a thing.
Meanwhile I will go back to my diet of Twinkles and hostess cupcakes at midnight in my attempt to add some natural padding.
From what I learned about seating position, if you rest your wrist on top of the steering wheel, you need to have a bend and relaxed enough position where you can turn the wheel side to side as much as you can. This can also be resolved by the telescoping wheel if you are taller. In this case probably not an issue.
For the legs, you need to have a slight bend in your leg so that you are not fully extended when depressing the clutch. I like to be able to fully depress clutch and still have a bend even if the friction point is not at this point.
I will see if I can get some measurements of how far the firewall is from the back of the seat.
So I just went out and measured. With the seat fully fwd, it looks to be a very close so you would think that the length from seat back to firewall will be close. If you measure from firewall to seat back, straight, I got 42". The seats are very deep so depending on your body type, it will make a big difference in length to clutch fully depressed. If you are smaller and fit all the way to the back of the seat, it makes the length further vs someone who does not go all the way back. I would compare to your current car where you are comfortable and do the same measurement. I think best would be to get into another car with lwb to see how you feel.
I have never had a problem with ANY car before.
That would be a good fix, thanks! I just hope I don't even have to get to that point. I'm thinking to check out my GT4 as soon as it gets delivered to the dealership and if it's so far back I'll ask them to adjust the rails so when I pick it up, I won't have a problem.
I just sat so perfectly in the 991 GT3 AND had room to slide the seats forward more if I needed.
Where can I find official information in this? Maybe if I can PCNA?
You had to sit all the way forward with no room to get even closer if desired?
I agree - it's weird that the GT4 wouldn't have sufficient adjustability to fit someone 5'4".
You might be able to fabricate some steel plates - mount them to the stock mounting holes and drill another set of holes forward of that to mount the seats? That way you aren't hacking into the body. Just an idea....
- if all GT4 LWB seats have the limited forward adjustability. Hence why I'm looking to know everyone's experience, especially if they are under 5'5.
- if I can unbolt and adjust the seat rails
Most importantly the latter.
Yea, that may be a good idea. I will have to go to a body shop if I have a problem and that would be a good idea.
Just throwing that out there, b/c 5'4" is a pretty common height in the general population and I doubt Porsche was making this car exclusively for Scandinavian males.
Maybe try this - measure the distance from your seatback to the pedal floor in your current car. See if someone with LWBs can move their seat fully forward and do the same measurement. Short of trying out a car with LWBs, that may be your best estimate. There will be some variability due to the depth of the LWB bucket so it's not going to be exact.
EDIT: Looks like anselmw did that already for you in his car....42 inches
I like Pete's idea of a cushion, that should work if you need more reach.
Again I think it depends on your driving style, I am sure you can reach the pedals but do you like pushing the clutch with minimal bend in your knee or the normal amount of bend.
Not sure where you are but someone around you must have a GT4 with buckets you can try.
Mr.Nurse, at the DeMan event this Saturday if there is a LWBS GT4 present, I will try to see if the seat position matches what I have in my GT4 (wrapped up for winter).
I'm very sensitive to seat position and on my 987S I always set the seat position 3 notches from the front. I also moved the seat back every time I get out of the old and new car, force of habit and it doesn't bother me.
I am 6'1" and I enjoy the LWBS for the GT3. I have no experience sitting in a GT4.
The LWBS in the GT3 definitely move more forward than I would need. My knees will touch the dash before it is maximally forward.
The LWBS move a long way back which makes getting out easier. I think getting in and out of the GT3 is not a real problem at all.
I would definitely go with LWBS on a GT4.
If I was concerned about reaching pedals; I'd definitely confirm fitment. I would not spend $90K on a car that has sub-optimal fitment. I would check out all 3 seat options BUT as we all know there are few cars to confirm fitment. I would have my Dealership SA do a lot of work and get some agreements in writing with regard to who will make adjustments of seat rails ect before I was committed. That's just me!
Here's a line to show where I measured. I got 42". The pedals don't touch that back wall though. When I press the pedal all the way down, there's about 2in. from the pedal to the back. I don't sit all the way back in these seats.
My lady who is 5'6 1/2 measures at 36"
Yea, I'm looking to try someone's GT4 seats before I take delivery.
30" is about .5" shorter than mine if I'm measuring correctly (bottom of hip bone to the floor).
30.5" from bottom of hip bone to the floor.
When is your lock date? Hopefully you can find someone close to try them again.
Everyone measures inseam differently is the problem. I'm actually a 34" inseam but wear 32" inseam pants.
Slight tangent, haha.
