Suncoast tinted tail lights for GT4.. thoughts??
#31
i needed to swap the connectors between the old lights and the new ones.... however no error code ...
#32
Anyone ever import Super Famicom games from Japan for your SNES as a kid? Same deal
#33
nothing to file down mate.... only removed the connectors from the oem rear lights and putted them on the new ones... no need to modify anything....
#35
2nd Gear
I have a NA Spec 2014 BS and changing out the tail lights as well with the Euro ones (opposite of what you did). Do you have any pictures you could share and any details on how/where you removed the connectors from the OEM lights?
Looking at the light assembly, it looks like there is a connector just inside the taillight that could be swapped with the OEM one, but not interested in forcing it. Any help would be greatly appreciated on how you did this.
Cheers,
Rob
#36
2nd Gear
GTS European Rear tail lights - Euro to North American (NA) Connector
That's really clean.. Thanks for figuring this out!
Cheers,
Rob
Cheers,
Rob
After removing the OEM light, disconnect it from the circuit board inside the light housing, remove the OEM cable from housing and install it onto the European Spec rear signal light housing.
#38
I like the look of the GTS lights, and the GT4 tail lights are worth more money ($1200 each I think) so I contemplated doing the swap which would be easy work. But I am both cheap and lazy and didn't want to remove/scrape/cut any of the rubber protective crap that covers the access to the light fasteners in the fender wall so I kept the stock lights.
#40
Sunset does ( I bought two sets )
Nothing to cut or scrape ( takes 10 mins each side at the most ) Unless your speaking of the euro versions ?
And I think they look pretty awesome
No tears for you
No tears for you
#41
I was wondering how those tail lights would look on black and they look pretty sick. Kinda thinking about them now... I need time off from this forum...
#42
