12 O'Clock Marker
Yellow 12 o clock marker is the single option that I wished I got but couldn't (I tried getting it but was denied). I'm tempted to rig some sort of yellow fabric (think thick tread) in the two groves currently at 12 o clock to get a "pinstriped" effect... I wouldn't embark on this project until the replacement wheel with marker is made available on suncoastparts.
I was also denied even that it was available in the configurator.......I think if you try to dye or paint the area the dark base color of the current alcantara will darken to much the yellow. We need to see up close an actual Steering wheel with this option....and while it doesn't help the car in any way or make it perform better it just looks right on a GT car.
on my RS alcanatra wheel its painted. The one I saw on gt4 at my dealer was painted also. Also tried all interior packages and only the yellow package comes with this as available. Makes no sense but then again we are talking Porsche here
Anyone know what thread that was on or who it was ??
Regards
Ed
JVCC Stage-Set Spike Tape is a 1/2 inch wide gaffers tape that comes in 19 different colors. Spike tape is a narrow gaffers tape which is used to mark stages and for other color coding applications. Since it is a gaffers tape it will not leave adhesive residue behind when removed, can be torn by hand, and will not reflect light. Applications for spike tape include: color coding & marking; spiking stages; gaffing lights and bundling wires.
http://www.findtape.com/JVCC-Stage-S...FUYWHwodA5cOZg
I'm not exactly sure what you're saying, but for me I believe it does help- basically for the reasons in the two previous posts.
Here you go.
https://rennlist.com/forums/991-gt3-...cheap-mod.html
Here you go.
Here you go.
That is a different thread but thanks for the effort
I think some guy said he used yellow surgical tape of some kind ?
Best
Ed
Looks like the strip is sown in. I have this on my order and if it doesn't work out, I'm planning the same upgrade as what I had on my GTS.
Attachment 999368
Attachment 999368
Here you go.
Here you go.
But I guess its hard to really pick without first seeing the factory finish.
I have the yellow stripe in my car. I just took a closer look and it is dyed yellow alcantara. I am so used to the one in my M3 that I had to get in for the GT4. It was open for a short time before my order locked so I was lucky to get it on my car.
