Tire cracking in cold weather
-I have an insulated garage at my home and my condo has a heated underground garage. For my home, I use old pieces of carpet under my tires and have never had any issues with cracking or flat spots. Keep in mind our cars really only sit for about 4 months (max) so its really not enough time to cause any damage. I know others who use plywood in their garages and have had similar results.
Best upgrades I chose were:
Max extension to the width of the single garage (which was a 4 ft width increase). Room for a fridge and plenty of room to work around the car.
Insulation (as discussed)
A faucet in the shared space (where I attached a hose reel and 50 ft hose). The hose works for both in the garage and outside the garage where I typically wash my car.
Drain in the middle of the double garage.
My dealer said that one of the 918's arrived on a cold winter day. They unloaded it an it sat outside for maybe half an hour while they moved the truck and made space for it. As they drove it off pieces of rubber started chunking off of the tires. I have my last track day with the Dunlops this weekend and I have a set of Super Sports waiting at the dealer.
Attached to Tirerack's description of Sport Cup 2 Tires is: "Storing Track & Competition DOT Tires in Cold Temperatures," which says:
While these recommendations are general guidelines offered by Tire Rack, selected tire manufacturers may have additional specific recommendations applicable to their tires. Follow the tire manufacturer's recommendations whenever available.
It is not recommended to drive on these types of tires at temperatures below 40 degrees F (5 degrees C).
It is recommended these types of tires be removed from the vehicle and stored indoors at temperatures maintained at above 32 degrees F (0 degrees C) when not in use.
Tires accidentally exposed to temperatures of 32 degrees F (0 degrees C) or lower must be permitted to gradually return to temperatures of at least 70 degrees F (21 degrees C) for at least 24 hours before they are flexed by adjusting inflation pressures, mounting them on wheels, or using them to support, roll or drive a vehicle.
I talked emailed Damon at TireRack and he said the tires "should" be OK in a garage that's not heated but not super cold (say 35F) as long as the car isn't driven and the tires are at max pressure for storage.
I'll be putting the car on 1 inch rigid foam that I have sitting around. I might install a garage heater or risk the tires.
These (or similar) are so inexpensive. If you work on your car or have R compound tires either on the car or off you may as well go ahead and get one. Cost is about the price of 1 tire. Never mind your personal comfort and piece of mind.
http://www.northerntool.com/shop/too...7749_200577749
For you Canadian gents, I do have a solution for your cracked tires....
get yourself a nice place in Florida, Arizona or California for the winter and your worries are over.
Plus, you can then drive your GT4 all year.
I am changing my tires to Michelin super sport and will daily drive my GT4 even in winter days, excluding snow days. I have done that with my M3 with Michelin Super Sport tires for last 10 years without any problem.
Sorry, running summer tires in winter isn't a good idea. They're still hard as pucks and have hardly any grip in the dry, nevermind if you get caught in a bit of rain. All season could get away with it in the dry, but still a master of none tire.
Typical of a bmw driver, .. I swear I see the same m3's & z4's, spinning their tires at the bottom of my street every winter! lol
FWIW, I think the mpss come with the same cold weather warning and the corvette guys have seen cracking from cold temperatures too...
MPSS is still a good tire driving above 35 degrees and in the wet. Below these temps best to have winter tires or drive a beater or other winter car. We drive the SUV
Addict & Guru
Originally Posted by ajw45
FWIW, I think the mpss come with the same cold weather warning ...
