Xpel Headlight delamination issue
In the 18 mths I owned my 991 the headlights got peppered with chips (and I stored it over winter!).
I live in New England so crap on the road is a matter of fact.
Im not sure you could polish off the remaining film without burning the lens and ruining the light .
As i said in my first post i priced a new light and it was $6,000 each for the PDLS+. When i polished it all i did was to feather the edge of the area that was starting to peal from removing the XPEL. carl
I believe if some coating comes of you're typically looking at wet sanding (and then polishing) to get all of the damaged coating off. You need to get back to the bare polycarbonate base layer and start again, applying a new UV coating. This is where headlights fundamentally differ from most taillights. Acrylic taillights hold up to UV attack well, and are easy to polish when scratched, however they couldn't withstand the impact from stones that are experienced on the front of a car and that's why polycarbonate is used. The downside with polycarbonate though is that it's not inherently UV resistant, hence the specialist coatings that are applied.
The rub there is trying to find an aftermarket UV coating that is 'pro grade' enough to be able to restore the headlight to something close to OEM look and functionality. You can walk into a parts store and get replacement clearcoat for your paint easily, but not so for headlights.
There are plenty of topical UV coatings (basically glorified polishes with mild UV inhibitors) that come with headlight restoration kits, but IMO they're not up to the job and not a real replacement. You have clear headlights for weeks or maybe months and then you're back to faded & yellowed headlights because this is simply not a substitute for the UV clearcoat that the OEM sprays on in the manufacturing process.
The only thing I've seen on the market that is potentially 'the real deal' is a spay coat sold by Glass Mechanix. I have purchased this but haven't used it, and I don't go recommending products that I haven't used, however promising they may seem.
If anyone has a late model Porsche headlight that is trashed/doesn't function and being replaced I would happily pay shipping for it and potentially even buy it just to play around more with the Glass Mechanix product. I am that nerdy.
)- mine goes on this Friday.
After getting my car done today I saw just how easy it is to remove the front headlight. It takes the most of 2 minutes to remove both headlights. To bad no one makes a dummy light to fit in its place. I decide to go with the blue tape on track days and not cover my lights. BTW anyone in NE FL who wants a a PPF should give Cool Conceptz a call to install Xpell. This guy knows his sh-- tucks all the edges uses carbon blades to trim and does a jam up job!!
