I'll bet the understeer will be dialed out with a proper track alignment. Some aggressive front camber is all it will need
Agreed. Softening the front bar and stiffening the rear will only get you so far. The front needs to be made more "positive" by adding camber and adding some to the rear will help the car rotate in slower corners.
still it beat the 458 and R8 V10 Plus around the track...
Key note here on track time; Streets of Willow is a smaller, tight track, so it would be ideal for the Cayman GT4 as some of those cars behind it would not be able to fully use their power. Regardless surprised to see it beat the 458 on the Streets - that is saying something.
Much of the footage was shot on Big Willow (adjacent track), where it likely would not have faired as well to the higher HP cars behind it in lap time. Big Willow is a high speed track and HP really makes an impact.
I would like to see its lap times compared at Laguna Seca, where both aspects are rewarded - corner speed and straight away speed. This track will better show where it fits in with other world class cars. My guess is for the money you won't find a better car period!
^^^ It does push a little on stock settings. I recall Harris and others adjusted the sway bars to get it to neutral.
But you may also recall AP mentioned to CH when the car is up in the air later in the video and CH mentions set up that AP states "well you like a oversteer set up" (not exact words but that was the message). So he is maintaining stock setting as being good (maybe all around better for typical driver on public roads).
Yes. Video Jounalism = Drifting.
I imagine everything is not loose enough for the current state of car reviewers. Fun to watch, but few chances in real life to drift a GT car at will. Instant black flag at most DEs.
Randy Pobst is a professional driver though and he thought it understeered a bit as well.
I recall some reviews stating that the 981S X73 had turn in understeer. Perhaps with the amount of power of the GT4, Porsche wanted to make sure it has stability on corner exit. I also wonder with the strut rear suspension, whether understeer was the preferred handling balance to prevent any sudden oversteer. Who knows.
Interesting calculation they did r.e. the gearing. Apparently, if 1st and 2nd were geared for 35 and 65 mph, 0-60 should end up at around 3.5 seconds! As it is, the quarter mile time (12.3 @ 115 mph) is pretty stellar. I know it's not a drag car but, still, more torque to the rear wheels could only help lap times (even with more shifting).
However, the gearbox is just too short for off-track driving. You don't get to use the lovely box much, 2nd gear gets you from a stop sign to the on ramp.
You mean too tall.
Originally Posted by acey81
Interesting regarding the understeer, there is one other clip where the car is understeering quite a lot (lap of Magny Cours) but in most reviews it is not mentioned at all.
So, is it a setup issue (Motortrend claimed Porsche tried to adjust it but it was still not perfect) or maybe it is sensitive to tire wear? If it was a common treat of the car, one would think it would definitely come up in any performance oriented review, right? Obviously you will see some understeer in any road legal car, but surprising to see it mentioned in this way, and still it beat the 458 and R8 V10 Plus around the track...
They did say that they were judging it by the highest possible standards and using the GT3 as a reference point, which is probably going to be more prone to oversteer than the average car both by being rear engined and by virtue of its setup guided by its design goals. And of course different drivers have different styles, so I think whether this car is too understeer-y will depend a lot on the driver. I remember reading that the GT4 comes with both sway bars in their middle position because Walter feels that's the best and most balanced setup, so I'll certainly give it a try that way before presuming that he doesn't know what he's talking about!
Originally Posted by Quikag
Harris went full hard on the rear sway and full soft on the front, I believe, to get most of the understeer out on his test video.
That's correct, but Harris also likes to hoon around, and I don't remember him setting a lap time in that video, so that setup may shift the balance too much the other way unless you just like having a loose car.
Originally Posted by mm1
Thanks! I don't buy into pure track numbers too much as I'll never hit close to these numbers and worry more about the street experience but still impressive:
I agree, but keep in mind that the cars below it don't come with Cup 2 tires, but rather MPSS or similar. They would all easily close that time gap and more if they did. Still extraordinarily impressive though, particularly considering the price.
And it was Streets, not Big Willow, as a poster above indicated. Very short, tight track. Still, that's a very quick time for that track.
I wonder if after making that calculation they confirmed that the tires would provide the necessary grip to hit that time.
That's certainly been Nur93's experience. He changed his sway bar settings and still has a fair amount of understeer, as you can see in the graph about a third of the way down the page in the link below.
On an unrelated note, I know the Track Precision App has been generally criticized, but Nur93 seems really impressed with the data he's able to get from it, including the understeer data by corner.
I wonder if you ever use anything other than 2nd and 3rd on Streets. Funny I thought the tall gearing would be a problem on a tight track like that. Seems not to be too much of a problem though.
If you follow the Upshift Indicator on the dash you could find yourself in 6th at 35mph.
