Sponsored by: APR
Brake squeal on standard brakes
Old 08-18-2015 | 01:52 AM
  #31
ShakeNBake's Avatar
ShakeNBake
Originally Posted by KA MOTORSPORT
Certain pads even under similar on track conditions and car setups can offer improved stopping power without always generating the extra heat...that can be a real gain. We have tested pads which have offered less bite than others but generated more heat into the brakes.
Its' why we look at caliper and rotor temps individually as a piece of the car setup when doing setup. We don't always run the same pads everywhere and "data" is all relevant.
I can tell you from personal experience that if a pad which generates about even 10-15% more heat into the brakes in certain cars and tracks translates to higher avg brake temperatures over the length of a stint and by the end of a certain races...can cook the brakes or leave the equipment pretty dead looking. Even with a driver using less pressure initially from the better stopping power...the overall confidence can be lost by the end when most needed.
Example: Some pagid endurance pads generally don't generate a lot of heat to the brakes and sometimes work better in certain high temp conditions over others. That is why many teams use them still.
Interesting. Last time I went down this path to figure out what pads generate the least amount of heat (before a buddy shook me to my senses and explained the laws of thermodynamics again), it turned out to be gradually failing caliper seals - which were causing the pads to drag. Fixed that and suddenly temps went way down, less rotor cracking, more life out of the same pads.
Old 08-18-2015 | 02:39 AM
  #32
KA MOTORSPORT's Avatar
KA MOTORSPORT
Former Vendor
Default Brake squeal on standard brakes
We always run rotor paints and caliper temp stickers on all of our cars...but prefer live infrareds if possible as that is better but pricey. we check and service our calipers and brakes every few races too (new seals, hardware, etc..). Every component has a certain time limit (usually 5000 km or so for cal seals) and not worth it to lose track time over not maintained equipment.
Quick Reply: Brake squeal on standard brakes
