New Cayman GTS to have 370hp!?
#46
I just hope that they get the exhaust sound right.
A couple Subaru WRX's drove by yesterday and they are 4 cylinder boxer turbo engines and they sounded terrible.
I don't think it's possible to match the awesome exhaust note of the current NA GT4 because the turbos alone quiet it down significantly.
#47
With the new variable compression engine that Porche has come up with the new generation of turbos will have NA feel to it under high compression and then drop to low compression once the Turbos kick in. I can only imagine the feel will be amazing, no lag just straight up torque right from the time you hit the throttle.
#48
Not sure you guys have seen this GT4 review so I thought I'd share it.
http://www.automobilemag.com/reviews...an-gt4-review/
They go on to say:
"Porsche’s next-generation turbo engines, just around the corner, will deliver more power and achieve better fuel efficiency (the GT4 is 15 percent worse than the Cayman GTS on the European cycle), but they won’t give you goosebumps like this engine does."
Guys, I'll tell you a little secret...."I Love Goosebumps."
They go on to say:
#52
